DJI FPV - Aircraft not bound to phone number - iPhone 11
12Next >
4184 75 3-5 19:19
eddie.eddie
Flight distance : 65105 ft
Got my FPV today and was super stoked to fly it but was locked out to only a 50' radius. There's a message that says "aircraft not bound to phone number" in the lower right of the goggle display as being the causee. It was mentioned that this is supposed to be set in the DJI FLY app, but I've looked and looked and cannoit find a place for a phone number anywhere. Also, How. come the Fly app doesn't have DJI FPV doesn't list as one of the models to connect to? Thanks.
3-5 19:19
rcpilot23
Same issue with mine. I have connect the phone and run the fly app each flight.
3-6 20:44
Bigplumbs
Flight distance : 306158 ft
Have you updated the fly app if on Android you have to go to the DJI app store
3-6 22:52
rcpilot23
yes using an iphone 11
The activation was successful and I have flown the drone with the goggles today
but the same message shows in the goggles unless I connect my iphone and run the fly app again
3-6 22:56
DJI Gamora
Hi, eddie.eddie. Thanks for reaching out and posting your concern. We'd like to know more about the issue you're encountering. Please make sure that you're running the latest version of the DJI Fly. If you're running an Android device, please download the latest version of the DJI Fly here: https://www.dji.com/downloads/djiapp/dji-fly
If you're already using the latest version of the DJI Fly, you can either clear the cache memory of the DJI Fly or uninstall then reinstall it before logging in to your DJI account.
Should the same problem persists, kindly upload a screenshot of the warning or error you're encountering so we can check it further. Looking forward to your response.
3-6 23:06
fans0ba40108
Hi, i have the same problem. Sorry the text it on french on the picture.
3-7 00:41
Eusjan
Flight distance : 224321 ft
I have the same problem, see my post.
3-7 00:55
Eusjan
I got 1 step further, DJI Fly app, connect the goggles with cable, switch on the drone, in the app go to profile-click on your account name-adjust your region manually, that saved for me that I don't have to keep my phone connected, but only after restarting my drone.
Also I noticed that when I tried to reload my firmware via the MAC, it sees the drone and connect and downloads but I can't transmit the firmware to the drone, it gives a time out, same as with downloading the flight records.
3-7 01:39
eddie.eddie
DJI Gamora Posted at 3-6 23:06
Of course I did all the obvious stuff.  iPhone 11.
Message goes away if I connect my phone to the goggles and I'm running the Fly app. As soon as I power cycle the drone, the message and flight limit comes back if my phone is not physically connected.
3-7 01:39
fans0ba40108
no one has the answer?  it's still incredible this bug
3-7 05:09
rcpilot23
yep I have been in contact with DJI support on facebook and they are looking into it.
hmm
3-7 06:09
fans8b9b4ffb
Norway
I have the same problem, when the googles are connected to a running DJI fly App the distance are ok, but when I disconnect the phone the limit is 50m.
Had the same issue with Mavic Air2, but this drone could I bind to my DJI account in the app.
3-7 06:14
markinter
Flight distance : 655331 ft
Very frustrating uninstalling 5 times switching otg cable, clearing cache, resetting goggles, enabling fly app access to phone etc. Had drone several days and only fly 50ft away and if I did decide I wanted Dji care and refresh it's too late since I've had no way to test drone. I tried a different phone on approved list and same thing.
3-7 23:21
jdmagoo
Flight distance : 1229554 ft
I have the same issue, just did a firmware reset and still the same problem
3-7 23:23
DJI Gamora
eddie.eddie Posted at 3-7 01:39
Thanks for your prompt response. We'll have this concern forwarded to our team for further checking. Should there be any update, we'll have you notified immediately.
3-7 23:43
rcpilot23
LOL DJI support advised me to uninstall the fly app then reinstall and connect the goggles.
FAIL
WTF
They must be able to set the drone to reactivate either by remoting into the drone via a pc or with a firmware.
3-8 00:51
jdmagoo
rcpilot23 Posted at 3-8 00:51
FAIL
WTF
Ive tried everything including:
- logging out of fly app
- clearing the cache
- deleting the fly app
- re-installing then clearing the cache a second time
- logging back in
- Still no luck!!
Ive also conducted a firmware reset on craft, goggles, and remote then repeating all steps above with no luck!!
Grrr,.....
3-8 01:47
Jimbetto
Same problem here ! I need to fly with my iphone connected... doesn't work even if I connect my Samsung S20 :-/ Waiting for a fix....
3-8 05:37
thewoozie.aol
Same issue with my DJI FPV.... aircraft not bound to phone number message unless I connect my phone with DJI FLY running after every power cycle of the aircraft.  Then the message goes away, and I can disconnect the phone from the goggles, and fly normally, until a new battery or I power cycle the drone.  Then I have to repeat the procedure to go fly normally.  And yes, I have tried everything....  reloading firmware, reloading DJI FLY, Re-binding everything, Clearing cache, Restarting DJI FLY.  Even tried to log in to DJI FLY using my phone number, but that only gave me an error that my email wasn't valid even though it asks for email OR a phone number.  Frustrating, and I'm on the edge of sending everything back to DJI for a refund.  In fact I will be deciding today. This is not as advertised.
3-8 06:55
Censurion
Flight distance : 448192 ft
thewoozie.aol Posted at 3-8 06:55
New products always have "startup problems" Think DJI will fix this shortly.  I have the problem also but why send everythink back? You have to know by now that every new product has always some issues. That is the reason that in the beginning you shall see a lot of firmware updates to fix them.
3-8 07:13
fans0ba40108
while waiting for a Fix, I plug my iPhone 11 into otg, I open dji fly and the message is removed, and I unplug the smartphone and it's OK.  to do with each battery change
Don't work with Android....
3-8 08:49
eddie.eddie
DJI Gamora Posted at 3-7 23:43
Thanks.  I'll keep an eye out for the eventual firmware update for this.
3-8 10:16
tomekyo
Flight distance : 3072087 ft
I have THE solution for you all. I'have been sitting and puzzling for two days trying to get support from DJI technical support - which is completely f... useless. Make a new account, and activate the drone with it. Try to do it outside, where the drone has the chance to get the GPS signal. I am not sure about the last one but I am sure it did help in my case. I believe that the drone "thinks"it is still in China where this procedure is required. I hope it is of any help.
Cheers.
3-8 12:27
fans0ba40108
Thanks, but no possible for me because i activated care refresh with my account !
3-8 22:30
QuadcopterGuide
Flight distance : 828904 ft
DJI Gamora, same issue here. iOS latest DJI Fly App. iphone 12 Pro Max. Retail DJI FPV Drone Combo.
3-9 01:38
craivold
Just for anyone else having this issue. Spent all afternoon trying to get my new DJI FPV up in the air with no joy. After a few tries of different things that didn't work including uninstalling/re-installing, switching phones etc.... the support guy suggested reversing the OTG cable that connects the phone to the goggles. Literally flipping the connectors around. This got me straight in to updating firmware. Battery is completely toast in the goggles now and needs re-charging but I think I might be able to fly it soon after an afternoon of messing about. Hope this helps someone else in this situe!
3-9 09:39
tomekyo
craivold Posted at 3-9 09:39
I'll put it here so you can easily find it:
Cheers.
3-9 10:14
craivold
Saw your comment on another thread Tomekyo. I was not keen on setting up a new account but would have tried it eventually because of your success with it. Luckily simply swapping which way round the OTG cable that goes from the goggles to my phone worked for me.
3-9 10:28
eddie.eddie
craivold Posted at 3-9 10:28
Assuming you must be on Android. Reversing the the cable with an iPhone is not possible as the business end of the cable going into an iphone is a lightning connector, not USB-C.
3-9 11:00
fansf00d7a18
Czechia
Petr
Hello everyone,
does anyone already have a solution to this problem? I have the same, I'm frustrated. The drone is new, it only has one flight. I have paid DJI Care, registered to my email. The drone is activated, a new FW is loaded. DJI fly has been newly installed, the cache has been cleared. I have a Huawei P40 Pro. When I connect my phone to Google, the binding message flashes but doesn't disappear completely. And I can fly a drone up to a maximum distance of 50m
In the DJI Fly application, the drone cannot be bound in any way, even when the phone is connected to the glasses and everything is switched on.
3-9 14:48
fansf00d7a18
Czechia
At the end of the video....
3-9 15:11
eddie.eddie
fansf00d7a18 Posted at 3-9 14:48
Hello everyone,
Welcome to the club!  The workaround that works for me is this:
- Power on controller
- Power on drone
- Launch DJI Fly app
- Connect iPhone to Goggles via USB-C port
- Power on Goggles
It's annoying but at least I can fly this way until DJI releases a fix.
3-9 15:56
Halifax
Flight distance : 326949 ft
It sure would be nice to see DJI acknowledge this problem so that we know a firmware update will fix it.
3-9 17:56
jdmagoo
The fix that worked for me is this:
- log out of fly app
- clear the cache
- log back in using a new account
- clear cache.
- plug your phone into the goggles using the OTG Cable
- ensure the drone is outside for good gps reception
- power everything on
- wait for a good satellite lock
Power everything off
- unplug your phone
- log out of the fly app
- clear the cache
- log back in using your original account
- then plug the cable back into the googles
- turn everything back on
- wait for a good fix
- turn everything off
- unplug the cable
- turn everything back on to confirm the fix
So far this has fixed the issue for me
3-9 23:04
Bigplumbs
Having to do all that is mental once again DJI releases a drone without proper testing
3-9 23:32
Halifax
jdmagoo Posted at 3-9 23:04
- clear the cache
OK, the combined tomekyo + jdmagoo solution worked for me this morning. Thanks, Friends!
3-10 09:38
WayneMann
Well I just tried jdmagoo's fix and so far it is working.  Thanks for that.
Wayne Mann
3-10 10:57
djiuser_fIwX48J4Bjzr
Flight distance : 55295 ft
fans8b9b4ffb Posted at 3-7 06:14
For all beginners, you need to delete the download cache to fly without that message, "flight restricted, please bind your phone number "
3-10 14:46
fansf00d7a18
Czechia
- clear the cache
Hi All, Great..... I tried the procedure according to jdmagoo. It works great !!!
Thanks All
3-10 14:53
DJI Gamora
Our apologies and we're still checking the cause of the mentioned issue. Please help us by extracting and uploading the Log folder from the DJI Fly. To do that, please connect your mobile device to a computer and locate the DJI Fly Folder. Kindly upload it either on DropBox or GoogleDrive.
Kindly send us also the following information via DM.
1. DJI FPV Serial Number
2. Screenshot of the About Page (should include the DJI Fly version and the DJI FPV Firmware version)
3. DJI Account
4. Location wherein you're flying the DJI FPV
Thank you for your cooperation and looking forward to your response.
3-11 00:17
12Next >
