Mark_2
DJI Stephen Posted at 3-8 19:31
Hello there Mark. Good day and thank you for the inquiry. Just a reminder that if the SD Card is formatted, the SD card that is less than or equal to 32GB should be formatted in to the FAT32 file system while the SD card that is larger thank 32GB should be formatted in to exFAT file system. Thank you.
thank you. Can you give me some guidance on the procedure on formatting the card in the drone? I had the controller and the drone on and connected . I chose GS RTK and tapped the 3 bars in the upper left corner. there was an icon for a sd card at the bottom but it has a red x. Do i need to format the card in the controller?
Thanks for all the help. |
