Flight logs will not sync
910 7 2015-7-12
kleake1
Flight distance : 1361040 ft
New P3, hooked it to my Samsung S6 edge and did a few flights.  Logs would not sync, they would get to 30% then jump to the end and fail.  Eventually after trying several times, they said successful and all looked good.  I plan to use my old S5 for most flights and keep it in the case with the P3, but then when I went to sync my flight logs none showed up.  I flew it a couple of times using the S5 and it has it's own log, but none of the devices sync with each other and keep failing.  What is the trick here?
2015-7-12
Rigworker
Flight distance : 52303 ft
Were your flights ober 15 minutes? There are several threads about longer flights not syncing. I know they do not sync if they are over 15 minutes on my android device.
2015-7-12
kleake1
Yes, so far they were 16-18 minutes or so.  If they won't sync any longer, that's kinda frustrating.  I'll try some shorter flights and see what happens.
2015-7-12
kleake1
Eventually, late tonight during another flight the logs uploaded, but as you said, anything longer than 16 minutes failed to upload.  Seems odd, but at least most of them did upload.
2015-7-12
aburkefl
Flight distance : 78612 ft
kleake1@gmail.c Posted at 2015-7-13 06:02
Yes, so far they were 16-18 minutes or so.  If they won't sync any longer, that's kinda frustrating. ...
I've had mostly short flights on all my Phantom flights. The first few times I synced to the cloud, they seemed to go just fine. Then, about three weeks ago, no matter how many times I've tried to sync, it always fails. Sometimes the numbers say "56%" then goes directly to fail. A few times I've seen the numbers reach something like ("92%") and then fail.
Been a long time since I've seen the sync work for me. I just basically quit trying.
2015-7-14
kleake1
Yep, that's what I am seeing.  As previously posted, anything longer than 15 minutes will not likely sync.  Hopefully that will be fixed in the next update but we'll see.  I don't always use the same device for each flight, but being able to sync them sure would be nice, especially since that's what it's supposed to do.
Also, is there a place that tells what the info is.  For example, some of my flights have a green dot to the left near the "favorite" star, but not all.  What does the green dot mean?
2015-7-14
klintb
I am having the same problem.  Had to delete logs to get it to sync.  At least I now know why because I had several long flights.
2015-7-14
tomd62
Flight distance : 16952 ft
I've got a strange problem, my flight logs are on the cloud, but I want the .TXT file for offline analysis, my Android phone seems to have stopped storing them.
It's got plenty of space and I noticed it a week ago and figured it was time to upgrade to the newest DJI-go app. Still no local .txt file in Internal storage\DJI\dji.pilot\FlightRecord
Can I download the cloud logs somehow?
One other thing, my phone has a much bigger SD card, how can I set the app to store all videos on the SD card instead of using the phone memory?
2015-8-23
