Activation Tips
1484 5 2021-3-10
tone7
Flight distance : 342723 ft
Here's what I learned struggling through the activation process:
1. Upgrading firmware failed with the Mac version of DJI Assistant but succeeded with the PC version. On the Mac, download step completed but transmitting step failed, many times.
2. I ended up with two versions of DJI Assistant 2 on the PC. The original installed years ago called "DJI Assistant 2" and a new copy called "DJI Assistant 2 (DJI FPV series)".
3. Activation failed to start when connecting goggles to long end of USB-C-to-USB-A-to-USB-C cable plus dongle combination, but worked with the dongle on the goggles end, iPad running DJI Fly App to the long end.
2021-3-10
tomekyo
Flight distance : 3226991 ft
Just connect the stuff as described in the quick start manual and activate and update the firmware using the phone and FLy App.
2021-3-10
djiuser_65eInVOkJTGs
March 8, 2022: PC version failed to activate multiple times. Maybe Putin told Ping to stop activating US drones.
2022-3-6
ro_flyer
Flight distance : 7557283 ft
Brazil
tomekyo Posted at 2021-3-10 09:18
2022-3-8
TomFarranL.A.
and after hours of frustration , you will realize your device is not compatible with the drone.
2022-5-2
Chaosrider
Flight distance : 1226762 ft
I just got my DJI FPV last week, and I had some activation heartburn. Here's what I finally did that worked:
1) I already had DJI Fly on my Samsung Galaxy S20 Note, from my Minis
2) Turn on the aircraft first
3) Turn on the control second.
4) Turn on the goggles
5) Plug the goggles into the phone
6) Start DJI Fly
At that point it just works, but you do have to watch it, because some times it asks you to approve stuff. Be sure to close all other apps on the phone before starting the process.
This worked for me, but YMMV.
TCS
2022-5-4
