System Sensor error, GPS error
12Next >
16479 48 2021-3-13
zombiepilot
I just got my FPV drone in the mail and after setting it all up I took it out for a first flight and everything went fine. came home to charge all the batteries and when I turned everything on again I got a "System Sensor Error" and a "GPS Error." I tried restarting the drone but i still get the messages. anyone else have this issue or know how to fix it?
2021-3-13
djiuser_ozlN8F6G55ID
Flight distance : 183517 ft
Same thing happening here - I've re-run calibration and refreshed the drone firmware - still happens
2021-3-13
supernicko
Flight distance : 203002 ft
Me too same errors sensor and gps and when looking in goggles I get 0 satellite connections- I’ll look under the plastic dome see if I can find any loose ribbons or plugs
2021-3-14
tomekyo
Flight distance : 3226991 ft
supernicko Posted at 3-14 00:08
fellows, you are outside correct? Because if you are not you might try to give it a go there, where the satellites are - outside ...
2021-3-14
anything? check the top board over with usb microscope or macro shot... didn't see anything unusual for mine or the side boards.
2021-3-14
supernicko
Can’t see any bad connections tried recalibration imu and compass in drone worked fine- camera works - dji assistant 2 recalibrate sensor works as does refresh firmware - just not connecting the gps and sensor I assume gps is the top chip with the fpv sticker on it - and white black cable runs down left and right side towards the sensor array seems to be the connection tot the top rear coax mini plugs maybe antenna maybe sensors not sure - got me beat I can’t be bothered sending in I wanna play more I even painted go fast gt stripes on her !
2021-3-14
Went through all the same troubleshooting steps with support, ended up getting it exchanged via reseller. hope the next one doesn’t hit any issues
2021-3-15
supernicko
djiuser_ozlN8F6G55ID Posted at 3-15 19:10
Hey there - any chance you have any logs or copies of your conversations - looks like im going to have to try the same and im sure it will help if i show it has been previously an issue and fixed with an exchange...
Anyone else feel free to post the same it would be pretty awesome if you could - ill keep it updated with my info see if it can help others... supernicko@bigpond.com
2021-3-16
zombiepilot
Same here. Contacted DJI and they are setting me up with a replacement.
2021-3-17
djiuser_ng2bL6c0dGWx
same ... the pic is home bute the same sh... outside
2021-3-17
supernicko Posted at 3-16 16:48
Phone convo but basicaly confirming I exhausted the troubleshooting and calibration steps.. try it in a few different areas, inside, outside, reset everything, refresh firmware, IMU and compass calibration, goggles and controllers work with sim.. camera on drone works.. drone won't take off with error messages and RED N....
2021-3-17
djiuser_IwJVjwGfOVdy
Flight distance : 1191388 ft
I only got this after replacing the dome to green one. Bought mine no issues now I changed dome and this crap. Changing back to the clear I'll keep posted.
2021-3-21
djiuser_IwJVjwGfOVdy Posted at 3-21 16:14
Nope still getting same error...
2021-3-21
szacs93
Flight distance : 4143743 ft
Hungary
Hello All!
Let me tell you you are lucky this happend for you while you were on the ground. On 21st mine got lost with the last message "Sensor system error" over a lake.
Yesterday I raised a ticket with the support. I hope I will get a new one...
The story in short: I was flying in manual mode and then the image transmission signal was weak (I think it tried to switch to normal mode and come back). But it was gone.
I think in manual mode the sensors are not being actively monitored only if you switch back to normal or sport mode. (There were noo errors on the Goggles before the signal issue.)
I hope your cases get resolved shortly
2021-3-23
Buzzyone
Flight distance : 4647913 ft
The GPS board on the drone is self contained and outputs the GPS data to the control board. So any GPS problems will be confined to that board. The two antenna cables, I believe are the ADS-B antennas feeding into the GPS board.
If you can’t get a lock then I would return as faulty. I have had a few Mavics in for repair where there was a dry solder joint on the GPS antenna to the PCB. As it’s under warranty then I would be using it.
2021-3-23
djiuser_FOZjefmeMeZg
Greece
Hello guys. I have the same error messages. I bought this drone on Saturday and only have 2 flights. There hasn't been a crash and the drone is in pristine condition.
Yesterday i powered on to check my battery levels and i show the errors! This morning i contacted my dealer and went to have it checked. Now i am waiting for a replacement (RMA)
Here are some photos i got from the goggles
2021-3-31
ApoIIo
Flight distance : 36860 ft
djiuser_FOZjefmeMeZg Posted at 3-31 08:52
Replaced mine under warranty. If it happens again ill be annoyed
2021-3-31
FlyingSnoopy
Greece
As i said on the other topic, i returned mine yesterday to the dealer and i am waiting for the RMA process to complete so i can get a replacement. I am really sad !
2021-4-1
ApoIIo
FlyingSnoopy Posted at 4-1 12:34
It is sad man. I was extremely annoyed. I really hoping it’s just a bad Batch of drones and now a model wide problem. I would love to hear from DJI if they are investigating the issue.
2021-4-1
Riwak
Flight distance : 996506 ft
Exact same situation for me here ! We are Beta tester...
2021-4-3
FlyingSnoopy
Greece
Riwak Posted at 4-3 12:05
This is exactly what my dealer told me! We are beta testers!
I got a replacement unit and in the middle of the first flight i got a yellow spot, look here:
https://forum.dji.com/forum.php? ... D767%26typeid%3D767
2021-4-3
ApoIIo
FlyingSnoopy Posted at 4-3 12:11
Far out! What the hell is going on with these drones lol
2021-4-3
Rob_G
Flight distance : 56732 ft
Wow, I'm just shocked at all the hardware and software issues that many seem to be having with the DJI FPV.  Bad pixels, can't activate (blank goggle serial), sensor errors, transmitter issues etc.  It just seems to be a wide gamut of quality control issues affecting many different components.  It's a shame because I really wanted the DJI FPV, but I bought a Mini 2 instead.
Rob
2021-4-6
djiuser_rGkMf0dvhPJN
South Korea
Same problem sensors error/gps error
2021-4-6
Arbie Cawilan
Japan
Is there anyone how to fix this problem
2021-4-17
fansb0b342a7
Flight distance : 8212 ft
Belgium
I am experiencing the same problem, the device keeps saying there is a gps error...
2021-4-17
fansb0b342a7
Belgium
2021-4-17
djiuser_sYlyUkiVgcaV
Adding another one to the pile. Talked to DJI this AM and they said "yea send it back". I got mine from Amazon so it should happen relatively quickly.
Just highly frustrating and worried it'll happen again.
Got the drone 4/5 days ago. Flew 3 times. No water, no crashes, only sport and normal mode.
Changed from the clear cover to the green one (that I painted white), and got this error the next time I powered on.
Tried recalibrating everything I can find to recalibrate. Reinstalled firmware update. Let it sit over night. Triple checked both batteries on the drone were fully charged and all other batteries were charged. Tried with and without a phone tethered to it. Tried switching back to the clear cover. Tried with no cover. Inspected all the internals as best I could.
Nothing changed it.
It DOES look like you could easily dislodge the two small plugs behind the chip with the FPV sticker on it (they're under a sticky foam pad), but I checked those and they were solid. Then tried unplugging them and plugging them back in.
Absolutely seems like a design fault in the drone itself.
The only other thing I did "differently" between it working and not working (Showing "GPS Error" and "Sensor System Error"), was do a few training courses on their Virtual Flight app (which also required adjusting the control stick).
Can anyone else chime in with whether or not they've had this happen after FPV training? I doubt it's related, but can't hurt to take a roll-call.
Replacing the clear cover with a painted one though seems to be the most common denominator.
I should have my new one on Wednesday (May 12, 2021). I plan on testing it out, then immediately swapping the covers to see if that reproduces the same issue. I'll try to remember to report back.
2021-5-5
Nothing changed it.
2021-5-5
Arbie Cawilan
Japan
I already fix mine, and I’m flying again with no issues.
2021-5-7
South Korea
Arbie Cawilan Posted at 5-7 19:43
how was fixed?
2021-5-8
sbarton
Flight distance : 877110 ft
You have to send it back and get a new one.
2021-5-10
Robpca81
Looks like I will be shipping mine back! Never even got to fly it once!
2021-5-12
Spikemixture
Flight distance : 49918 ft
Philippines
djiuser_sYlyUkiVgcaV Posted at 5-5 17:55
Yep mine 'unplugged' with very little force - that I am aware of ! And I could not 'replug' them.
I sent it back and they repaired it but now get the errors mentioned here.
Has everyone here that gets this error changed or taken off the cover ?
2021-5-12
FlyingSnoopy
Greece
Spikemixture Posted at 5-12 22:58
Like 9 out of 10 people got this error by replacing the cover.
I got a replacement drone, but i am not going to change the cover untill i have enough fun with it.
Around September i will try to repalce the cover and see if i get the error again.
P.S I doubt that the problem is the plugs on the back. Probably there is a disconnection of the flex tape between the GPS module and main module
2021-5-12
got my “replacement” from Amazon (I just ordered another one before returning my original one)
I wanna fly it for a bit before replacing the cover again. However, I have confirmed it’s the drone itself. Not the controller or goggles (not that there was much question of that, but at least it’s a little more information).
I’m using my original goggles and remote with the new drone and it’s currently working.
Pretty shocked DJI’s still silent on the matter.
2021-5-13
fans5230e465
Flight distance : 70325 ft
Same problem. Just yesterday try to change the cover. At the end of the process the problem appear. Try to plug and unplug the tiny cable on the back but nothing happens. Just opened an RMA ticket. I’m waiting to have answer from DJI. So sad
2021-5-13
supernicko
supernicko Posted at 3-14 17:23
FIXED : it sat on a shelf for months as i couldnt be bothered with the bs of sending it in.... saw on a similar thread a guy who replaced his gps - works out its EASY AS! Once your cover is off, its 2 screws, 2 little antenna plugs which stay intact with the sticky tape - and 1 little data plug - so easy -  i bought the original part from my local supplier - plugged in - turned on - all back to normal. SENSOR ERROR AND GPS ERROR are gone and ive just flown 3 batteries. Thought id post incase it helps - i have refresh and i know it was prob under warranty but for $40 USD i couldnt be bothered... As a side note the gps chip antenna basically press against the cover - so for those saying they took the cover off check your plugs first -but im wondering if the pressure of the cover there can bust the chip.. or a light crash could easily put pressure on it. Hope it helps - NICKO PERTH WEST AUSTRALIA!
2021-6-21
JOT
Puerto Rico
supernicko Posted at 6-21 01:32
Hey Niko, so the only thing you replaced was the GPS module/antenna of your DJI FPV?
In my case, I got only the "Sensor System Error". My drone does take off, but the message is always on the goggles screen. I cannot notice a problem with my drone in addition to the on-screen message. But I'm afraid there is a problem a should fix that may prevent my drone during a high/far flight get lost.
2021-11-15
djiuser_TCi01B462Nru
supernicko Posted at 2021-6-21 01:32
Hi Nicko, thank you for your post. Can you give me a little more detail on how to change the sensor. Im not a tech person so its a little hard for me to follow. Also, which part (how does it look like) did you buy and replaced. Im so loss and not sure where to begin.
2022-1-11
12Next >
