sultangris01
this isnt really an accurate description of the problem, unless the reason its not charged to 100% is cause it self discharged. if you fly a fully charged battery down to 80 percent for example and then later in the day or the next day even fly it again without charging it you will have no issues, unless perhaps you set the auto discharge to 1 day. i have mine at 10 days and use the same battery a couple or more times for separate flights without charging all the time with no issues, every time i use a self discharged battery without charging it, this problem happens. the self discharge screws up the accuracy of the readings and causes the problem. FYI |
