Error code 30136 overheating
1596 3 2021-3-14
COOLDR73
Good afternoon,
I have a DJI Mavic Mini drone, when it does a self test, error code appears 30136 over heating? and turns off.
Any ideas on easy repair if possible.
I have seen a list of error codes but not for this error code.
any info would be appreciated.
Kind regards,
2021-3-14
DJI Stephen
Hello there COOLDR73. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please power on the DJI Mavic Mini and let it sit idle for a while, after some time please check whether the fan spins. If the fan rotates and still the issue persist or if the fan does not spin at all. It would be best to contact our DJI Support Team at https://repair.dji.com/repair/index?site=brandsite&from=nav for further assistance. Thank you.
2021-3-14
COOLDR73
Hi Stephen,
DJI mini doesn't have an on board fan!
Can you assist with another idea why this has occurred?
2021-3-14
m80116
Flight distance : 3264131 ft
There are heating transfer pads transferring heat from components to the external shields and heat sink. Probably one of the tabs has shifted inside or it's lost contact with the either the component or the shielding.
It can be fixed quite easily if that is the case.
2021-3-16
