Firmware upgrade not recognized
436 1 2021-3-15
deathbypancakes
I recently purchased the DJI FPV Combo but an unable to get the firmware update to be recognized.
I downloaded the FPV Assistant 2 (DJI FPV Series). I connected each device and upgraded the firmware. The goggles still say the aircraft and goggles firmware need upgraded. When I connect the devices FPV Assistant 2 says the they are running V01.01.0000 and there is a red box with the word current in it. I have tried refreshing the firmware via FPV Assistant 2 several times for each device. Each time it states it is successful but the goggles still say the firmware needs updated.
Any help would be greatly appreciated.
2021-3-15
Buzzyone
Flight distance : 4647913 ft
I had a similar problem with Assistant 2 when adding the Motion Controller. I updated the firmware with Assistant but when trying to fly, it refused as the firmware required updating, even though it just had been.
Connect to the DJI Fly app to the goggles, it will resolve the problem, make sure aircraft and remote are also powered up.
2021-3-15
