Can you program it to climb to a certain altitude in fail safe return mode
830 2 2014-11-24
duckhunter10
altitude on return mode
2014-11-24
mixstreme
in the app and assistant software,,, take a look.
2014-11-24
kenargo
There are a few ways to handle this.  As mentioned above you can set the default using the Assist software, you can also set it by flying higher than nearby obstacles as the Phantom uses the higher of the configured return height OR the current altitude.  Think of the configured altitude as the minimum value.
2014-11-24
