Where do you put your operator ID
25449 38 2021-3-17
stupat78
Flight distance : 1204259 ft
Hi, finally got around to making myself and my drone legal. Got my operator ID and  did the flyer ID at same time as was free. Where on the mini 2 are you guys putting you operator IDs? I was going to put it inside the battery cover but if you follow the guidelenes for text size etc it doens't fit unless you cut it to fit over two lines instead of one.
Just curious what peoples thoughts are on having it on dsiplay on the outside of your drone as well?
2021-3-17
jweaver
Flight distance : 47664 ft
I just printed a label and stuck it on top.. and at the same time stuck my mobile number on another lable as I have with all my planes/quads.
I did this after adding an FPV and Gyro to a plane and taking it out for its longest ever flight.. But got so excited I forgot to monitor the battery.. I turned and never saw it again
To this day I wonder that if I had my phone number on it, someone might have found it and called me.
2021-3-17
sbonev
Flight distance : 3665279 ft
Switzerland
i have put it on the back left arm - wrote it down on a sticky label. a bit ugly but "visible"
2021-3-17
yogi053
Flight distance : 26104915 ft
Viewed from the rear, sticky label on rear right leg facing the viewer and also labelled the batteries with the same label. I think I will put my mobile no. on the rear left leg as well.
2021-3-17
TDZHDTV
Flight distance : 2068550 ft
I used 4mm text and fixed to the back of the front arm, it’s discrete and doesn’t spoil the look of the drone
2021-3-17
stupat78
Bodkins Best Photography Posted at 3-17 14:05
Last I checked an operator ID wasn't required for the mini 2, which is the forum you're posting in.
According to the CAA website it does as it has a camera. Doesn't require a flyer ID though.
2021-3-17
delf67
Flight distance : 379449 ft
Sticker on top.
Mobile no. is a good idea.
2021-3-17
sbonev
Switzerland
OP is in UK, hence Europe, you are in Canada - how do you know better than us local regulations and why you think so?
2021-3-17
delf67
sbonev Posted at 3-17 15:39
UK no longer in Europe!
UK CAA makes UK drone rules, not Brussels!
2021-3-17
DJI Stephen
Hello there stupat78. Good day and thank you for the inquiry on where to place the operator identification on your DJI Drone. I hope that our fellow DJI co pilots can give out there recommendation where they place the said operator identification on there DJI Drone. Thank you and fly safe always.
2021-3-17
DAFlys
Im UK,  Mine is on the flap for the battery.
2021-3-18
stupat78
DAFlys Posted at 3-18 00:41
On the inside or outside?
2021-3-18
DAFlys
stupat78 Posted at 3-18 00:44
On the inside.  When you open the flap and look in the text is readable.
2021-3-18
yogi053
stupat78 Posted at 3-17 14:21
You are correct stupat78, and you are posting also in the correct thread.
2021-3-18
LeChuck71
Flight distance : 68786 ft
delf67 Posted at 3-17 16:40
Belive me the UK is still in Europe, but not a part of the European Community
2021-3-18
sbonev
Switzerland
sorry but last time i checked UK is on an island that is still considered part of the European continent, no? and believe me i know and i am glad UK is no longer part of EU. Good riddance to that. Nobody needs bunch of whining babies that cannot decide which way the wind blows.
2021-3-18
JohnLietzke
Flight distance : 3125968 ft
Brothers label maker with clear tape and white lettering looks closer to the DJI white emblems.  But I switched to black lettering to make it less obvious.
The clear tape is by far the cleanest choice and not very visible.  I initially started with individual small precut white letters.  But even the smallest size letters was way too big and looked janky.
2021-3-18
Mavic57pro2
Flight distance : 3772247 ft
Mine is labelled on top between the front legs, this is not going to interfere with anything. I also put Name & tel. No. in the hope someone will call if I lose it.
2021-3-18
whiteghost
Flight distance : 1479705 ft
Thought rules changed in Dec 20? If you're drone has a camera then you have to have both ID'S
From UK caa:
You must register before flying most drones or model aircraft outdoors in the UK.
There are two requirements and you may need to meet both:
if you’ll fly, you must pass a theory test to get a flyer ID
if you’re responsible for a drone or model aircraft, you must register for an operator ID
One free pay for the other?
2021-3-19
stupat78
whiteghost Posted at 3-19 05:53
From UK caa:
The rules did change but a mini 2 does not require a flyer ID as it is under 250g. I have done my flyer ID anyway as it was free.
It only requires an operator ID even though it's under 250g as it has a camera and is not a toy.
2021-3-19
yogi053
Again, you are correct stupat 78. Operator id must be on the drone, at least 3mm high symbols and readable without having to disassemble the drone to read the information.
Flyer id not required on the drone, YET. But the person flying the drone must be registered at the time.
2021-3-19
stupat78
yogi053 Posted at 3-19 08:42
Does the person flying the drone have to be registered though if it's under 250g? If that was the case then a flyer ID would be required.
2021-3-19
delf67
LeChuck71 Posted at 3-18 06:48
Yeah, ok. But the subject was drone regs, so I was just saying  that we are not in Europe as far as regulations are concerned, we have our own.
2021-3-19
yogi053
stupat78 Posted at 3-19 09:05
[view_image]
I'm still a relative newbie at this hobby, so I don't profess to know all that is required to be 100% legal whilst flying drones. The drones that I fly just now are less than 250gms and are fitted with cameras, so at the moment, the drones display my operator details and I carry my flyer id details on my person in the event I am requested to show them to any authorised person who needs those details. I do, in the future want to purchase heavier and better equipped drones but will probably wait until the 2 years grace of flying 'legacy'? drones is finished. Then again, I may just buy one now and fly it for the next 18 months or so. Who knows? Nice conversing with you stupat78. Stay safe!
2021-3-20
marcel_911
Flight distance : 18901 ft
I just stuck a great big label on the top. No point in me trying to disguise it.
2021-3-21
deepanshus
Flight distance : 78891 ft
DAFlys Posted at 3-18 00:49
Just to clarify, thats not a legal position for the OP ID. It should be visible outside, unless i am wrong.
2021-3-22
DAFlys
deepanshus Posted at 3-22 04:53
It’s quite legal. It has to be visible without requiring tools to access it.
2021-3-22
DAFlys
Here is the instructions from the caa.
How to label your drone or model aircraft
Your operator ID must be:
  • visible from the outside, or within a compartment that can easily be accessed without using a tool
  • clear and in block capitals taller than 3mm
  • secure and safe from damage
  • on the main body of the aircraft
2021-3-22
deepanshus
DAFlys Posted at 3-22 04:58
thanks, i stand corrected !!
2021-3-22
DAFlys
deepanshus Posted at 3-22 05:52
On the Mavic pro 2 I’ve labelled the body of the drone but in the battery compartment.
2021-3-22
Peter Galbavy
Flight distance : 545377 ft
I use my Brother QL720W label printer with the ridiculously expensive but very good Yellow Film (DK-22606) and print a 29mm long label (62mm is the fixed width of the "paper"). Fits perfectly on the top of the Mini and Mini 2. In addition to UK Operator ID I also have
REWARD IF RETURNED
Property of Peter Galbavy
email / mobile (with country code)
UK/EU: GBR-OP-xxx
AU ARN: xxx
The last bit since I am also registered in Oz, and if this damned pandemic would ever go away I would probably be there about now...
2021-3-22
Peter Galbavy
[delete double post]
2021-3-22
UKMoose
Flight distance : 3657552 ft
This where I put mine, both sides, and phone number if found on the bottom.
PS this is not my drone.
2021-3-22
djiuser_lLgAAq48bjUr
Flight distance : 210 ft
TDZHDTV Posted at 3-17 12:28
I appreciate I'm bumping an old thread but how did you make that fit on the arm itself.
I've just bought a DJI Mini 2 and even printed at about 2.5mm, it's far too long to fit on the arm.  In fact, it looks rubbish stuck on the side!
Thanks.
2021-7-26
Feek
Also, my labels are rubbish, that's already started peeling!
2021-7-26
djiuser_oQKEvZiGY0mN
Flight distance : 482 ft
I printed it on a label and stuck it on the back side of the folding propeller leg. Its a nice flat surface with plenty of room for the label printed in a medium font for easy visibility.
2021-7-26
Gibb0
Flight distance : 118061 ft
delf67 Posted at 2021-3-17 16:40
Yes we are just not in the EU unless Britain has floated off somewhere
2022-6-9
djiuser_UM09CtFrlYCR
Do you need the sticker on the uk? Is it a legal requirement? If so how do I get one
2022-11-27
Ms Ivy
Flight distance : 19819813 ft
I printed mine and stuck them on each side. I was told when i got my p107 that I still had to have this on my drone so even though its a mini I still put it on for a few reasons. but the main 1 is if i had a fly away and got lost hopefully some that finds it will be honest and call me and tell they found it . but lets hope that never is needed right.
2023-1-4
