luciens
Yes the V2's will work. I have a set of V2's and I use them with my iflight Nazgul5 (Caddix Vista) and Titan DC5 (DJI Air Unit) and they work normally. MIne have the older .604 firmware, though, because I got mine before the FPV drone release. The new firmware, as everyone knows by now, is totally broken, so I don't know what happens when you try to switch to "Air Unit mode" with the new firmware. I believe it works, but you have to rebind everything every time you switch back and forth from FPV drone mode and air unit mode, or something like that.
As for the antennas on the V2's, they're dual band so they work on the 5.8ghz band already.
I do find the range is poor, the video signal starts to degrade only about 1/2 mile out at 700mw and even at 1200mw (with the 1200mw hack applied). So I suspect the V2's antennas perform a bit worse on 5.8ghz than the V1's antennas do. Luminier makes a set of dual band antennas that are supposed to be really good, but I haven't tried them yet.
But also I don't have a set of V1's to compare to either. The V2's antennas are simple dual-band dipoles, I believe, which is probably why they don't perform as well.
But, assuming the latest firmware isn't broken in Air Unit mode too, you will have no problems using the V2's with the Air unit or the Caddix Vista/Nebula Pro/etc.. They are fully functional with the air units.
