File size
1009 12 2021-3-18
SgtRay
Flight distance : 14860804 ft
When i go into the card to see the flight its always in two files
Is it normal for the flight file to be split instead of it being one large file?
2021-3-18
Renato61
Flight distance : 168163 ft
Your video is larger then 4gb? This is the limit in FAT32 and Android < 11 version.
2021-3-18
Jerry Luo
Flight distance : 24498 ft
Maybe you can solve this problem by using SD card >32GB.
2021-3-18
SgtRay
Jerry Luo Posted at 3-18 02:45
my card is a high speed 128
2021-3-18
SgtRay
Renato61 Posted at 3-18 01:51
in one vid at 4k it split the feed into 2 aprox 2.73 files of 4+ min each
2021-3-18
SgtRay
Oh and this is on my FPV drone
2021-3-18
AlanHd
Flight distance : 797365 ft
As stated the Fat32 files system has a limit of 4gb per file, ExFat will allow larger files. Check the specs to see if it is supported.
2021-3-18
Duane Degn
Flight distance : 622234 ft
My files are always about 3.6GB or less. I thought it was normal to break the video in to "manageable" files sizes.
This is a rather common trait in many action cameras.
2021-3-18
SgtRay
Duane Degn Posted at 3-18 12:07
I have a few that don't but they aren't 4K ether. lol
Thanks
2021-3-18
DJI Stephen
Hello there SgtRay. Good day and thank you for the inquiry. The maximum capacity of a single file will not exceed 4GB. If exceeded, the recording will be stopped, and a new recording will be started. In addition, the maximum file size of FAT32 is 4GB. Hence, a file that is larger than or equal to 4GB will be divided, otherwise, the file may be lost or abnormal and cannot be read. Although exFAT allows a larger file size, the larger file may be damaged due to abnormal power-off and SD card removal, or even cannot be recovered. So the storage of the camera is 4GB regardless of the file systems. So it is normal the video will be split if it reaches 4GB. Thank you and fly safe always.
2021-3-18
SgtRay
DJI Stephen Posted at 3-18 19:02
Thanks! That's good to know!
2021-3-18
DJI Stephen
SgtRay Posted at 3-18 20:01
Hi there SgtRay. Thank you for the reply and you are very much welcome. If you have any other inquiries or concerns with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Thank you.
2021-3-22
DAFlys
Nicely done.
2021-10-12
