MA2 RTH accuracy
690 2 2021-3-21
MaSky
Flight distance : 2345538 ft
Lithuania
Hey,
Could you please advise me, what should I do, that RTH accuracy would be better?
Now around 70% of flights, when RTH was initiated, drone lands ~1-1,5 meters from the point where it took off. In other words, it lands not on the landing pad.
Before taking off, I'm always waiting for at least 10 sats (usually more) and the home point everytime is updated.
Rest 30% of cases are quite precise - the drone lands on the landing pad.
Maybe it requires calibration or so? Have never done that.
Thanks
2021-3-21
MaSky
Lithuania
wamuBugMe Posted at 3-21 09:51
See the section of the owner's manual titled "Precision Landing" for some suggestions. It's on page 15 of v1.2 of the manual.
Thanks. Seems that I met all the conditions, which are mentioned in the manual.
2021-3-21
Labroides
Flight distance : 26781877 ft
MaSky Posted at 3-21 11:24
If your drone isn't auto-landing within inches of the launch point, it's not using the precision landing feature and is using GPS alone.
The accuracy of GPS can only position the drone within about 1.5 metres (sometimes even a bit more).
There's no calibration that would improve that.
Precision autolanding is just a gimmick anyway rather than an important feature.
You can land the drone precisely yourself if you really want it to land on the same spot.
Check the PL details in the manual again because something isn't satisfying the drone enough to use PL.
Are you launching vertically and stopping briefly at 7 netres?
Is the ground pattern/texture suitable, lighting good etc?
2021-3-21
