djiuser_277pDbv9SqTK
Flight distance : 167612 ft
RE: Inside the Controller
Duane Degn Posted at 3-26 08:28
You're right about the threads being M3. The pitch is 0.45 (there are also 0.35 M3 fasteners though I don't know if I've ever seen one).
Both of the screws have threaded sections of 11mm length.
The F1 screws are 13.4mm long. These screws are used to reduce the spring tension on the vertical axis of a gimbal.
Oh my god, I just hope, DJI promotes you to best support staff member ever and pays you a ton of money.
(especially the money of the other support members, because you are the only one I have got a real and accurate answer from. I wrote mail, posted and even tried to call the support without success...)
I tried unscrewing the two screws from the pitch/roll stick, and the result was ....nothing. they just don't have any function on that side.
So , now I got my throttle tight again, and even got an additional screw.
Btw, I love your project on hackaday.io. Keep it up, we definitiflly need exact information about what hardware DJI is selling us, without information.
Thanks again.
greetings Imp
