And it didn't disappoint. I tried both Cine and Normal mode and to be honest couldn't notice much difference. My only complaint would be 30fps at 4K isn't quite good enoughf ro a fast panoramic shot. It's very jerky. Other than that for the weight the Mini 2 is perfect for hiking the mountains. 4 clips here at 7:30, 37:51, 47:06 and 1:08:18.
Realy? Then you have to move more slowly or use 2k760fPS
Set the pan speed (yaw) to 6 degrees / second in the settings of the gimbal in Cine Mode, then it will not jerk even with 4k30.
