Pappy3
Flight distance : 2820469 ft
DJWacko Posted at 3-31 16:38
Yeah I figured that might be the case , but it’s still a great drone with awesome filming capabilities. Like you say practice,practice,practice. All I need is it to stop raining and I’ll be all set. Thanks for the reply Pappy3
Your welcome. As far as the practice goes, you'll need to find out what works best for you. There are at least two methods, thumb or pinch along with afore mentioned yaw/camera gimbal adjustments.
With thumb only on top I have seen three flavors of using this method, thumb on joystick socket only (no stick), OEM stick, or use a capped socket head hex screw to raise the stick higher to gain a finer level of control.
With the pinch method you place the stick between your thumb and index finger. The same stick options apply as for thumb only. I tried this method a few times, but I cold never coordinate the movement of the left stick and gimbal wheel being moved at the same time to provide smooth footage. |
