robt77burke
djiuser_hxjHbL0r9CJU Posted at 2022-7-18 21:22
I signed up here just to post this. I was using Samsung S20fe and getting constant moisture detection warnings. I tried clearing the cache in the USBSettings app, which did nothing. Plugged into a different phone and it was working perfectly, so shouldn't be an issue with the controller or cable. Reinstalled DJI Fly, didn't help. Tried safe mode on the phone, didn't help. Disabled fast charging, didn't help. Restarted phone 20 times with cable connected and disconnected, didn't help. The ONLY thing that helped was to turn the controller on first, then plug the phone in. With the cable "live" it seemed to bypass the moisture detection issue. I would only do this if you're 100% sure there's no moisture in your port on your phone and controller as it probably bypasses the moisture safeguard. Worked for me though. Good luck everyone
Did all that, then turned on RC then plugged in phone. didn't help. DJI needs to solve this issue. Wife bought me a $1000 DJI drone that only functions as a paper-weight and source of frustration. |
