System sensor error/GPS Error
1994 5 2021-3-30
ApoIIo
Flight distance : 36860 ft
Anyone had the error System sensor error and GPS error come up?
turn my drone on today to go for a fly and it just has that come up.
It will not fly.
I removed the shell to cheack if it was my new paint job and nothing is disconnected and it still gives me the same errors with the shell off.
I reset the system through the goggles and still same error.
2021-3-30
Whoreable
Flight distance : 1775299 ft
uh oh, not sure...I saw a compass error today flying N mode down some train tracks, the video also looks to be more wobbly in that area
2021-3-30
Whoreable
Re calibrate the drone, IMU and gimbal?
2021-3-30
ApoIIo
Whoreable Posted at 3-30 01:48
did that. I got the ...s now. im taking it back tomorrow
2021-3-30
Whoreable
ApoIIo Posted at 3-30 02:02
what did you say
2021-3-30
djiuser_sYlyUkiVgcaV
Adding another one to the pile. Talked to DJI this AM and they said "yea send it back". I got mine from Amazon so it should happen relatively quickly.
Just highly frustrating and worried it'll happen again.
Got the drone 4/5 days ago. Flew 3 times. No water, no crashes, only sport and normal mode.
Changed from the clear cover to the green one (that I painted white), and got this error the next time I powered on.
Tried recalibrating everything I can find to recalibrate. Reinstalled firmware update. Let it sit over night. Triple checked both batteries on the drone were fully charged and all other batteries were charged. Tried with and without a phone tethered to it. Tried switching back to the clear cover. Tried with no cover. Inspected all the internals as best I could.
Nothing changed it.
It DOES look like you could easily dislodge the two small plugs behind the chip with the FPV sticker on it (they're under a sticky foam pad), but I checked those and they were solid. Then tried unplugging them and plugging them back in.
Absolutely seems like a design fault in the drone itself.
The only other thing I did "differently" between it working and not working (Showing "GPS Error" and "Sensor System Error"), was do a few training courses on their Virtual Flight app (which also required adjusting the control stick).
Can anyone else chime in with whether or not they've had this happen after FPV training? I doubt it's related, but can't hurt to take a roll-call.
Replacing the clear cover with a painted one though seems to be the most common denominator.
I should have my new one on Wednesday (May 12, 2021). I plan on testing it out, then immediately swapping the covers to see if that reproduces the same issue. I'll try to remember to report back.
2021-5-5
