M600 Pro + Manifold 2 + OSDK / Getting video onboard
524 0 2021-4-3
djiuser_BJmDoN82HgpH
Croatia
I'm working on an application with an M600 Pro and need to get the  video feed from the Z3 camera to an onboard device for basic processing.
The Manifold 2 seems to be ideal for this application, but there are  some major problems:
The manifold-cam project on Github (github.com/dji-sdk/Manifold-Cam) seems to be abandoned. No meaningful commits in last years. Support questions go unanswered, including this one: dji-sdk/Manifold-Cam#15 which is exactly like a problem I have encountered.
The Manifold 1 seems to have been designed for only the M100/M210. It  uses 8-pin connectors for the cam in and cam out, while the gimbals on  the M600 use 7 pin cables.
For the Manifold 2 it is said it could use Ethernet over USB, but it is unclear where to connect it to M600.
Is there a way to connect the Manifold to the  Lightbridge 2 directly or camera gimbal with the M600 Pro wiring?
Is there any other way to get video from a DJI gimbal to an onboard device?
2021-4-3
