Pan axis alignment FAULT???
7514 20 2021-4-4
fans5e0e4445
Is it just me or is the pan axis not centred when locked? My gimbal looks ever so slightly out meaning the camera is ever so slightly pointing to the left. Note this is straight out of box and is now just a few weeks old with zero assignments done with it.
2021-4-4
dksri
India
mine is also having same problem .... i am also searching for the solution please let me if you resolved it
2021-4-5
fans5e0e4445
dksri Posted at 4-5 07:47
Sure thing! Maybe one of the mods can flag this with DJI to find out if its a batch design flaw or if its intentional and tell us why... @DJI Stephen
2021-4-5
fans534077f3
Flight distance : 1838924 ft
Mine was exactly the same when I got my RS2 - very annoying.
Using the app, I calibrated/reset the pan joint angle and everything has been spot on since doing this.
See post #11  https://forum.dji.com/thread-163488-1-1.html
2021-4-6
fans5e0e4445
Still waiting for input from mods and DJI
2021-4-6
fans5e0e4445
fans534077f3 Posted at 4-6 03:48
I just tried recalibrating the “horizontal” via the app... nothing changed. Still ever so slightly off centre. I might try to do a full reset later. I’m surprised DJI don’t allow for a manual correction of degrees in the app.
Still waiting on reply from DJI and mods
2021-4-10
fans5e0e4445
Formal query sent to DJI.
2021-4-10
fans5e0e4445
This is how it looks when locked off (gimbal off) Briefcase handle and monitor arm attached to NATO attachments illustrate how out of line it is.
2021-4-10
fans5e0e4445
With the gimbal on camera attached (balanced and unlocked) and double tap to centre
2021-4-10
fans5e0e4445
Camera base lined up
2021-4-10
fans5e0e4445
And cross referencing to a previous thread and issue with the RS2 it appears my pan joint angle is less than 1 so doesn’t require adjustment (according to that thread)
2021-4-10
fans534077f3
fans5e0e4445 Posted at 4-10 23:03
It doesn't matter what the app says, it's obviously not ok and is out of alignment so reset the joint angle and all will be solved.
Mine was the same, double tap to centre was out from new. Reset the pan joint angle even though the app said it was fine like yours and all has been smooth as silk since.
2021-4-11
fans5e0e4445
fans534077f3 Posted at 4-11 11:37
Okay I’ll give it a shot this afternoon
2021-4-11
fans5e0e4445
Okay so correcting the centre position via the joystick to the visual centre, holding down pan axis joint angle for six seconds in the app to perform a offset calibration works. Is it a fix? Well at least my camera is pointing the right direction at the expense of the arms looking out of line with the handle (about a 5 degree rotation to the right of centre). It doesn’t help that the tilt axis arm is not in line with pan axis arm which I would assume should be 90 degrees when looking down at the two, it’s more like 85.
I dropped 1000AUD on what I’d expect to be precision equipment but looks like it was built by a five year old. Very disappointing DJI...
2021-4-11
fans5e0e4445
Read through my post you’ll see I’ve resolved it by using the app as suggested by another user. Best of luck let me know how you get on.
2021-4-11
fans534077f3
fans5e0e4445 Posted at 4-11 19:54
What do the camera electronic levels look like?
Placing the gimbal on a level surface, does the image look off?
If any other of the axis is off, just reset their joint angle.
2021-4-12
fans5e0e4445
Horizontal level is fine. But looking at the angle difference between the tilt arm and the pan arm from above I would assume this should be a right angle 90 degrees and that the baseplate would follow the line of the pan axis arm, instead it is pointing inwards slightly. To compensate for this the pan axis needs to be biased even more to the right to have the lens pointing forward and centred. This added to an already offset calibration to correct the pan axis to centre.
2021-4-12
fans5e0e4445
fans534077f3 Posted at 4-12 13:51
Thanks yes horizontal isn’t a problem although I should check that when I get home. If you look at the photo with the camera on the gimbal you can see the alignment of tilt and pan arm isn’t straight (look at the angle of the camera viewfinder to the roll axis motor). This is compounding the pan centre issue and can’t be adjusted by app as the tilt/pan angle is due to the tilt arm bending inwards which is a physical flaw
2021-4-12
fans5e0e4445
If someone with an RSC2 can chime in with whether their axis arms display similar issues or not that would be very useful.
2021-4-12
fans534077f3
I can see what you are saying but I assume that the image was taken with a wide angle lens and not the best way to judge if the arms are lining up hence why I suggested putting the gimbal on a level surface and see if the cameras pitch and roll levels are ok. Pan the gimbal and see if these change.
Properly balance the camera on gimbal. Double tap to centre the gimbal and frame a scene with a window or door with horizontal and vertical lines in the frame. Take a still image with a standard to moderately wide lens so not to introduce lens distortion open in PS and see if there is any keystoning suggesting the gimbal is out of alignment.
2021-4-13
fans5e0e4445
And soooo I upgraded to an RS2 and everything is just dandy. Shame I got burned by a bad rsc2, it was bad there’s no two ways about it, it was bad out of the box, naughty DJI.
2021-5-12
