Update on Mode 4 Stick Mode for new FPV drone?
12Next >
7224 40 2021-4-5
MotB78
Switzerland
Hello DJI FPV Support and community!
Can you please give a short status about the implementation of Mode4 for the DJI FPV drone?
I am Mode4 pilot and would be very thankfull to be able to fly my DJI FPV drone in Mode4 in manual mode.
So dissapointed, that I did not recognize that before I bought it....
Thanks and BR
MotB
2021-4-5
DAFlys
Mode 4 was never promised for this drone.
2021-4-5
DJI Gamora
Hi, MotB78. Thanks for reaching out and posting your concern. Currently, this function is unavailable but we'll forward this feedback to our developers. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com or by checking the Release Notes specific for the DJI FPV.
2021-4-5
Duane Degn
Flight distance : 622234 ft
If you are willing to open up the transmitter, you could swap the controls by swapping wires. The gimbal wires are connect with plugs. If you pull these pins and swap them around, you could have a mode 4 transmitter.
In case you haven't seen it, I posted photos of the inside of the controller in this thread. There's a link to my Hackaday IO page with additional photos.
If you decide to go this route, I'd be happy to help identify which wires need to swapped.
2021-4-5
MotB78
Switzerland
Duane Degn Posted at 4-5 08:28
Hi Duane
that's what I did yesterday. I changed the wires for roll and yaw and have now Mode4 in the Mode2 settings. I did a testflight and the  controller still works. Also on Simulator (Liftoff) no problems.
I got a warning during flight, that there is an error on flightsticks, but I did not feel anything strange. Perhaps I have to recalibrate the controller in goggle settings?
Do you have seen this error / warning also?
Thanks
MotB
2021-4-6
Avronaut
Flight distance : 53996 ft
MotB78 Posted at 4-6 01:44
Hi Duane
Recalibrate could help
2021-4-6
Avronaut
DJI Gamora Posted at 4-5 03:03
It is incomprehensible why mode 4 does not exist. And it should be easy to make this possible.
2021-4-6
Duane Degn
Hi Duane
"I got a warning during flight, that there is an error on flightsticks"
The "F2" screw presses a button when screwed all the way in. The firmware thinks you screwed in the "F2" screw on the wrong axis. From what I've read, I think the warning can be safely ignored.
It's certainly possible to perform even more drastic surgery on the controller to disable the button but I don't recommend this. The circuit requiring modification is pretty hard to access.
The least evasive hack would be to find a way to depress the button on the original throttle axis without needing to modify the spring tension.
2021-4-6
MotB78
Switzerland
Avronaut Posted at 4-6 03:03
Yes, I can confirm. I did some testflights today and did not get a warning again.
2021-4-6
fans1ff03407
Flight distance : 147277 ft
Hi Duane
Hallo...
Bin auch Mode 4 Flieger...Würde deinen Umbau gern machen. Könntest du mir ein Bild senden von innen? Werden die Stecker oder einzelne Kabel getauscht?
Gruss Ronny
2021-8-26
GadgetBen
Flight distance : 446854 ft
I also fly Mode 4. It is ridiculous that we could set Mode 4 in all DJI Drones going back to original Phantoms but not on this latest, otherwise excellent Drone. Come on DJI please fix this in a software update and stop forcing us to hack your hardware to do it! I cannot get rid of 10 years of muscle memory to relearn how to fly!
2021-10-28
GadgetBen
I found a video https://www.youtube.com/watch?v=rOJG3w88FVk
2021-10-28
JustDrewit
It's hard to fathom why this seemingly simple and straightforward addition is being denied... There's a significant chunk of the population that you're shafting here DJI.
Can we please get a nod to this?
2022-8-22
fans63ece0f3
Austria
Are there any news on that? This could easy be fixes with a software update.
2022-9-3
C.Calabrese
Flight distance : 1940682 ft
I've started a petition for them to change this. I encourage everyone on this thread to sign and spread this. It's a simple software fix to allow this functionality, and ridiculous they're withholding this from their paying customers. A petition worked for Cine Mode (allegedly), let's force them to pay attention to a large subset of their customers.
https://chng.it/GZQR55tdvV
2022-9-21
Yves Mattle
Flight distance : 74944 ft
C.Calabrese Posted at 9-21 22:51
Cool thing, I signed immediately
That can not be that there is no mode 4....
2022-9-23
Yves Mattle
Switzerland
DJI Gamora Posted at 2021-4-5 03:03
What about mode 4, will this come in the next update?
2022-9-25
djiuser_L2hQrwmcX2SU
Flight distance : 341129 ft
Dachte auch, das Mode 4 kein Problem ist. Ich fliege den Mavic2pro mit Smart Controller. Hier konnte ich benutzerdefiniert Mode 4 einrichten.
Jetzt die Avata und FPV Drohnenset gekauft und wollte mich da herantasten. Geflogen habe ich beides mit Motion Controller. Jetzt will ich mit der Fernbedienung anfangen und richtig fliegen lernen und dann sowas. Mode 4 geht nicht. Nicht aufgepasst beim Kauf. Ich bin echt sauer!  Hier in dem Tread tut sich ja schon fast 1 Jahr nichts mehr. DJI interessiert es wohl nicht.
Ich baue in Zukunft meine Drohnen selbst.
Jürgen
2022-10-28
_b_n_y_
Any updates on this?
2023-3-29
DAFlys Posted at 2021-4-5 02:41
So was muss nicht versprochen werden, die 4 Mods sind normaler Standart bei guten Herstellern.
Weisst den Kunden mit dicker Überschrift darauf hin und ich hätte die FpV und Avata nie gekauft.
Aber das kümmert euch nicht. Hauptsache verkauft und Kohle ist im Sack.
Noch nicht einmal nachträglich wird sich Mühe gemacht ein -dusseliges- Update dafür zu machen.
2023-6-20
DAFlys
djiuser_L2hQrwmcX2SU Posted at 6-20 09:15
This is the problem when people make assumptions.
2023-6-21
mateen
Flight distance : 490850 ft
Is there seriously no fix for this still?
2023-6-21
R.Steudle
Flight distance : 577221 ft
I hope that with the new Remote Control 3 the conversion to mode 4 is also possible.
2024-4-11
DJI Paladin
Flight distance : 318 ft
R.Steudle Posted at 4-11 22:49
Hello there. Thank you for reaching out. We will coordinate this to our relevant team for further clarification. We will keep you posted.
2024-4-12
DJI Paladin
Thank you for patiently waiting. Unfortunately, this feature is not supported but we'll forward this feedback to our developers. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com. Thank you for your valued support.
2024-4-18
Emilio Marin Manzano
Como conectar el simulador, con gafas y mando avata 2? No consigo enlazarlo.
2024-4-20
atgertgmail.com
Flight distance : 790659 ft
Austria
Thank you for forwarding, it is now April 2024, the 3rd FPV Product is on the Market and still nobody cares about Mode 4, exellent work.
2024-4-23
atgertgmail.com
Austria
DJI Paladin Posted at 4-18 00:08
2024-4-23
SecondaryWorks
Finland
Chiming in - I bought an Avata2 without realizing that Mode 4 is not supported. Pretty PLEASE get this addressed, it has been YEARS. If nothing else, I need to rewire my controller in order for me to be able to fly in full manual mode.
I have to say that this is completely ridiculous that this easy of a fix can't be implemented in this amount of time.
2024-4-24
DJI Paladin
atgertgmail.com Posted at 4-23 03:11
Hi there. While we strive to accommodate all requests, some may take time to process. Our team carefully evaluates each one to ensure the best possible outcome. Additionally, we consider the hardware and software capabilities. This ensures that any changes or features we implement align with the device's capabilities. Rest assured, we're committed to providing the best experience for our users. Thank you for understanding.
2024-4-24
DJI Gamora
atgertgmail.com Posted at 4-23 03:10
We're sorry for the inconvenience, atgertgmail.com. Rest assured that all of your suggestions are being forwarded to our relevant team, however, we can't guarantee that everything will be implemented as it depends on their evaluation. Thank you for your kind understanding.
2024-4-25
SecondaryWorks
Finland
You know what, let's fix this. I'm modifying a Controller 3 below.
Open the controller and see that when going from controller 2 to 3 we've lost quite a bit of heat generating chips and one battery. There is one screw that has hot glue on top of it, I guess to detect tampering. This is different from 2.
Take a good look around and see that the hall sensor wires are actually quite long, let's take one off and see what we can do:
Oh man, "how convenient", we can just swap the hall sensors between the sticks:
Then we can reassemble:
You will get a stick error on your next boot up, but a calibration will fix that and WHOA WE HAVE A MODE4 AVAILABLE.
I'm amazed how cheap this thing is inside considering the price. I get quite a bit more mileage with my TX16S.
2024-4-25
Ben_McE
Flight distance : 815587 ft
SecondaryWorks Posted at 4-25 11:38
Hi there,
This is currently holding me back on my purchase of Avata 2. Is there any videos anywhere that show how to do this step by step? How has your experience been so far with it? Thanks
2024-9-1
SecondaryWorks
Finland
I think I watched a video of a person taking Controller2 apart and then used that as a baseline for disassembling Controller3. Other than getting the case open without destroying it the above photos detail the major steps in getting the sensors swapped between sides. Do be careful with routing the cables so that they do not get chafed off by using the joysticks.
In case you haven't found it, I have few more details available on a dedicated thread here https://forum.dji.com/forum.php?mod=viewthread&tid=311529
2024-9-9
Wilhe
Flight distance : 867175 ft
same problem here
2024-12-4
Wilhe
What a bad excuse for a bad service
2024-12-4
DAFlys
Wilhe Posted at 12-4 02:06
Should I complain then about my car, as it doesn't fly.
2024-12-4
The Duck
DAFlys Posted at 12-4 02:23
That's a terrible analogy.  Adding mode 4 is a simple software update and could be coded, compiled, and tested in a matter of minutes.  I don't get why you need to troll people who ask for a feature that would allow them to fly DJI's FPV drones.
2024-12-4
DAFlys
The Duck Posted at 12-4 10:27
If you think thats a job that would take a few minutes you have no idea about software development and testing.      It would take longer than that to update all the documentation,  in I dread to think how many languages.
2024-12-4
Wilhe
DAFlys Posted at 12-4 22:42
It´s copy and paste from all other Dji Drones
2024-12-7
12Next >
