Mavic Air 2 Range/Transmission Issue
285 11 4-7 22:43
MysticDrones
Flight distance : 413996 ft
     Hello, I recentely purchased a MAvic Air 2 a week and a half ago and have been flying it ever since. Everything goes smoothly, one problem i have is the range. I lose signal everytime at 2000 ft distance. The drone is marketed at 10 kilmoters so 2000 ft shoulndt be an issue. I fly in my neigbhorhood which is near an airport. I also downloaded the Mavic assistance 2 app on my computer and did some firmware update. This enabled me to fly to 4000 ft, but after 4000ft i would lose signal and thr aircraft woult auto return to home. As i gradually go farther the RC signal bars drop.     I paid $1100 for this and woulnd't want anything going wrong. If anyone has any information that can help me, please let me know. Thanks!
4-7 22:43
DAFlys
Flight distance : 1276493 ft
Try flying a little higher and make sure your orientated towards the AC.
4-7 23:32
DJI Stephen
Super Moderator
Hello there MysticDrones. I am sorry for the trouble this has caused and thank you for reaching out. Can you please fly your DJI Mavic Air 2  to a different location to see if the issue will still persist? The said DJI drone might have picked up magnetic interference from the area. That might be the reason why you are experiencing these issues. In addition, I will post a diagram on how to get optimal transmission for your DJI Mavic Air 2. Thank you.
4-8 00:14
DowntownRDB
Flight distance : 525 ft
Couple of things to try.  First make sure your controller is oriented properly to the aircraft.  This and a bit more altitude could help connectivity.  If you are still limited in distance then I would try flying in a different location.  Could just be you are picking up too much signal interference in your current flying area.
Flying nearby some airports I've picked up quite a bit of signal interference.  Could be from radar and lots of wifi.  Not sure but it does happen.
Hope you get the issue sorted out soon.
4-8 04:56
MysticDrones
DJI Stephen Posted at 4-8 00:14
[view_image]
Thanks for the reply, I am going to try and go fly in another location today, hopefully the problem doesn't continue.
4-8 09:44
MysticDrones
DowntownRDB Posted at 4-8 04:56
Thanks for the reply! I also think that the airport and myriad of wifi signals might be interfering with the transmission. I am going to try to fly at different locations.
4-8 09:45
ranrick
Flight distance : 795545 ft
Philippines
Try to fly higher clear of structures and signal interference causing sources. Though considering you live near an airport, the airspace would be pretty saturated with interference so this method might not work well too though. In that case, better try flying in a different location and check again. If in the case it still won't get far even in rural areas, then you might need to consult dji for a possible replacement.
4-8 21:26
DJI Stephen
Super Moderator
MysticDrones Posted at 4-8 09:44
Hi there MysticDrones. You are very much welcome and thank you for the reply. Kindly please keep us posted for further assistance. Thank you.
4-9 02:44
DowntownRDB
MysticDrones Posted at 4-8 09:45
You're welcome.  Let us know how you make out at the new location.
4-9 04:53
Larry Bailey
Flight distance : 70636 ft
Rather than start a new thread on the same issue I will post that I too am having issue with distance.  I tend to get between 500-700 ft with my mavic air 2 and smart controller which I received mid February.  I have gone to different areas and went to an open area out of town with a body of water.  I was at 256 feet and lost signal.  Wide open got a message aircraft not connected to RC.  My antennas were pointed down properly as recommended.  Also of note this is a CE drone and am disappointed that DJI does not advise that certain areas will have this rating as the 10k down stance is misleading.  I have also calibrated the IMU and compass again as recommended by phone support and still only 2-300 ft and my video breaks up stops, lags.  You can’t even aim at what u want to film
4-9 07:34
MysticDrones
     Thanks to everyone for all the replies!! the DJI community is great!. I took my Mavic air 2 to the beach yesterday and flew 3k feet with absolutely no interference and no dropped bars. I am 100% I could have flown much much farther. I am convinced that the signals and interference from my neighborhood doubled with the airport is messing up the drone, but since it works fine in other places, I can rest knowing its not defective lol. Thanks again, everyone!
4-12 07:04
David.Battle
Larry Bailey Posted at 4-9 07:34
I have found obstacles are very big problems as far as range goes.   Try to fly with a direct line of site keeping in mind that every tree and house between you and your aircraft will reduce the range.   A way to do this is to gain height as you go further away or start at a higher elevation.   Also make sure the flat part of your antennas are facing the drone.  If you fly a mile away at 200 meters then try to go low, you will almost certainly lose signal.
4-12 12:13
