won't connect to dji assistant 2
2211 13 2021-4-8
JimDandy
Flight distance : 144649 ft
Can't get the mini2 to connect to the dji assistant 2. Says "device not compatable" I've followed the silly Disconnect, power off re-connect within 20 seconds. Still nothing. Had to update via the phone. I'd like to do it through the assistant.
2021-4-8
JohnDG
Flight distance : 856801 ft
Malaysia
which version you have?
You have to use this version of dji.com
https://www.dji.com/mobile/mini-2/downloads
Also note that the only function at the moment is to retrieve flight data from the drone. Unfortunatly you can't update firmware from the Assistent.
If you have other drones like the Mavic 2 or Air 2, the version for the mini2 does not support the other drones correctly. If you have different types of dji drones you can both assistent versions on your pc (like I did).
succes!
2021-4-8
DJI Stephen
Super Moderator
Hello there JimDandy. I am sorry for the trouble this has caused and thank you for reaching out. The DJI Mini 2 aircraft can only be updated via the DJI Fly. Connecting the said DJI Drone to the DJI Assistant 2 will give you access only to the Flight Recorder. Thank you
2021-4-8
JimDandy
JohnDG Posted at 4-8 20:17
Thank you. I have the Mavic air 2 and it hooks to dji assistant fine. A friend of mine at work just got the mini2 and I could not get it to connect to dji assistant 2. We did all the updates on the phone through the Fly app.
2021-4-9
JimDandy
DJI Stephen Posted at 4-8 20:45
Thank you sir. Updated through the fly app, all set to go.
2021-4-9
JohnDG
Malaysia
JimDandy Posted at 4-9 06:11
the assistent for the air 2 and pro 2 or zoom is a different version of what to use on the mini 2.
I'd like to update also from pc instead of using the fly app. Still hoping DJI will update the functionality of the app some day soon.
2021-4-9
DowntownRDB
Flight distance : 525 ft
JohnDG Posted at 4-9 07:13
"Still hoping DJI will update the functionality of the app some day soon."
It would sure be great if that happened.
2021-4-9
JimDandy
Yeah, I down loaded the Mini2 version of the asst. 2 on my work computer to help my college out, It wouldn't connect, so we downloaded the updates via the app on his phone. Dji makes things hard sometimes. the assistant should be across the board compatible. It's a simple vehicle to load firmware. But NOOOOOO it has to be complicated. I like how the say "works with" mini 2 ....da da da. So you download it and jump through all the hoops of shutting it down and reconnecting and It still doesn't work. Then I'm told , "well you can't update with it, just upload logs" HA HA HA. EyEYyyEyE.
2021-4-9
RobZilla
Flight distance : 229350 ft
Ugh good to know about DJI Assistant and the Mini 2 vs Air 2.  At the moment I have an Air 2 and thinking of getting the the Mini 2 since I can get a deal on it. I would've done the same steps on the PC app until I came across this thread, so thanks for saving me the time and headaches on firmware updating.
On a similar note, is there any tips or gotcha's when using the DJI Fly app with BOTH the Air 2 and Mini 2?? Obviuolsy not at the same time, but will the app recognize when one drone is connected, or do I have to select it manually? Also will the app distinguish the flight logs separately?
2021-4-9
JimDandy
RobZilla Posted at 4-9 17:11
No issues with the fly app and the mini2. It works like a charm, no different than air 2. I use airdata app for capturing data. The data will be separated out by which aircraft created it. I like my friends mini2. It is very light, but seems to fly great. The batteries don't have a LED light system built in to them due to their size, The lights are incorporated in to the charging bank on his. He got the fly more kit with the 3 bay charger. If you can get a good deal on it, I think you'd be happy with it.
2021-4-10
JohnDG
Malaysia
I have no idea if it is possible to switch between aircrafts. I'm using an mavic pro 2 with an SC and a mini 2. On the SC it is possible to switch between aircraft profiles. But then again the mini 2 is not compatible with the SC. So, I use different controllers for both drones. :-(
2021-4-10
DJI Stephen
Super Moderator
Hi there JimDandy. You are very much welcome and if you have any other inquiries or concerns with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Have a safe and a happy flying always. .
2021-4-12
JimDandy
JohnDG Posted at 4-10 08:20
We're just talking about the fly app on the phone not the controller. Or Smart controller. RobZilla was asking about the fly app differences with the 2 models. He wanted to know if the fly app knows which drone is on, In his case it will be the air2, or the mini. The answer is yes it does know which drone it is.
2021-4-12
RobZilla
Thanks for the follow up and answer JimDandy. Yes I was referring to the app on the phone, not the controller or Smart Controller.
2021-4-12
