MavGuido
Flight distance : 338793 ft
Hey together,
i have an strange problem with tracking on a motorised slider.
If i want to track a subject in a half circle while i draw a frame on it via the app, everthing is fine until the slider stops at the end.
I thought that the tracking also stops while the movement ist over and everything stands still, but that is not the case and the tracking goes on some seconds.
That is very bad if you want to make a professional product shot.
Did anyone know while i run into this trouble?
I also check out the tracking speed, the framesize and everything else, but nothing would help.
Actually i had considered buying the extension set for 500€ in order to be able to use the slider better, but if there is no solution, i can leave it alone.
Can anyone help me?
Thanks and regard
