PERPLESITA'!
801 9 2021-4-10
DONA72
Flight distance : 42113 ft
Scusate se torno su questo argomento, perchè su Google Play Store non ci sono più aggiornamenti x la DJI GO 4 ...... è uscita da un bel pò la versione 4.3.42 e su Play Store non c'è, il motivo di questo cambiamento ..... io sono fermo alla versione 4.3.37, dovrei scaricare la 4.3.42 con l'AppGallery di HUAWEI ma è diversa l'app e il telefono và in tilt.
La versione 4.3.37 è di 238 MB con Google Play Store
La versione 4.3.42 è di 260 MB con l'AppGallery di HUAWEI
2021-4-10
DJI Gamora
Hi, DONA72. Thanks for reaching out and posting your concern. The DJI app you are using cannot be updated or downloaded via Google Play due to technical reasons. In order to ensure that the app can be used normally, we have opened a download channel on DJI's official website. You can visit our website at www.dji.com/downloads/djiapp to download and install the latest APK file to update the app. There is no need to be concerned, as user experience, functions, and privacy protections on apps installed through DJI's official website are still the same as before, so please feel free to use them. We also would like to remind you that you should only download apps from official channels. Thank you for your kind understanding.
2021-4-10
DONA72
DJI Gamora Posted at 4-10 03:15
Ciao Gamora ho scaricato la DJI GO 4 dal sito che mi hai dato  https://www.dji.com/it/downloads/djiapp/dji-go-4 ma come si fa a installarla sul telefono è un formato zip con la procedura come si deve fare. Grazie!
2021-4-11
DJI Gamora
DONA72 Posted at 4-11 01:18
The file, once downloaded, should have an extension file of .apk. Please check the download section of the browser you've used to download the DJI GO 4. Once you have located the file, just tap it once and that should inform you if you're going to install the DJI GO 4 apk file. Kindly wait until the app has been successfully installed and launch.
2021-4-11
DONA72
DJI Gamora Posted at 4-11 03:13
Scusa ancora Gamora io il file apk l'ho scaricato con il pc e come browser ho Google Chrome e nel file apk ho visto che c'è molte cose e non so cosa cercare come devo procedere o il file apk bisogna scaricarlo con il cellulare, non vorrei danneggiare il cellulare che in formato zip......non sono tanto pratico su queste cose.
2021-4-12
DowntownRDB
Flight distance : 1722 ft
DONA72 Posted at 4-12 01:48
Ho inserito una copia dell'app ufficiale DJI Go4 V.4.3.42 nella mia cartella pubblica della casella personale. La dimensione del file è 260 MB (273,189,738 byte). Ti ho inviato un collegamento tramite PM. Il collegamento è valido solo per 24 ore.
2021-4-13
DONA72
DowntownRDB Posted at 4-13 06:51
Ok grazie DowntownRDB
2021-4-14
DowntownRDB
DONA72 Posted at 4-14 01:26
Sei il benvenuto.   Spero che tu sia in grado di installare l'app.
2021-4-14
DONA72
DowntownRDB Posted at 4-14 03:00
Sono riuscito ad installarla ma l'app ho visto che è in cinese all'inizio poi è in inglese......se era tutta in inglese non era meglio, cosa sono tutti quei casini che fanno, senza offesa però!
2021-4-14
DowntownRDB
DONA72 Posted at 4-14 05:01
Mi spiace, ho avuto problemi anche con alcune delle loro app. Spero che il tuo problema venga risolto. Stai al sicuro e passa una splendida giornata.
2021-4-15
