CemAygun
Philippines
Herbie53 Posted at 4-11 08:40
Doesn't it suffice to just not press the batteries down when you insert them in the charging brick? If you don't press them down, they do not make contact (status lights do not come on and you cannot interrogate the battery status using the button on the brick).
Also, does someone have an idea how being connected to the unpowered brick can interfere with the auto-discharge function? Does the firmware inside the battery check for this connection?
We are all hoping this can be and will be fixed with a battery firmware update in the future, but as of writing they only discharge if they are not inserted into the drone or the charging hub. So basically the answer is "yes", they know when they are inserted and they don't go through the discharge procedures.
I personally would also recommend active discharging (use the charging hub as a power bank to deplete batteries) instead of waiting for 5 days, especially for the people that live in hot climates.
PS: The charging hub is "powered" as soon as a battery is inserted, it does not need to be connected to a charger.
