Smart Controller loose antenna
920 1 2021-4-13
Fabio98
Flight distance : 746319 ft
Hello,
I have my Smart Controller since October 2020 without any issues, but I noticed a few days ago that the antenna on the right joint is looser than on the left joint. Did somebody noticed the same on his SC? I'm a little bit scared that it could get more loose or maybe break one day. You can feel it when you turn the antennas or pull a little bit but only on the right joint. I have added one picture with the joints marked. I hope someone could test it on his SC.
Best regards
Fabio
2021-4-13
DJI Stephen
Hello there Fabio. I am sorry for the trouble this has caused and thank you for reaching out. May we know if the said issue is affecting your flight? In addition since this issue is happening on your DJI Smart Controller. I would recommend you to contact our DJI support team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We would do their best to help you and then the corresponding resolution would be provided. Again, I am sorry for the trouble and thank you.
2021-4-13
