Black screen with dji fly 1.4.0 and Galaxy S21 Ultra
12Next >
13284 51 2021-4-16
sonyp900
Flight distance : 6902142 ft
Greece
I just updated dji fly to version 1.4.0 ans having issues with my Galaxy S21 Ultra, preview screen in the app is total black. The weird thing is that histogram works ok, if I shoot a photo it captures ok, but preview screen is black. If i install an older version everything works ok, the same if I use my iPhone. Any ideas?
2021-4-16
jonny007
What should the update be good for?
2021-4-16
DowntownRDB
Flight distance : 1722 ft
I'm using a Galaxy S21 Ultra (with a Snapdragon processor) and having no issues whatsoever with App V1.4.0.  Do you have a Exynos processor by chance?  If so that could be the problem.  Seems many times when DJI updates the Fly App that mobile devices with the Exynos processor have issues with black screens.  Hope you get it resolved.
BTW, most of the changes to V1.4.0 were to add the Air 2S but did change a few other minor items.
2021-4-16
sonyp900
Greece
DowntownRDB Posted at 4-16 15:50
Yes I have Exynos...none of the other versions caused this problem. I installed 1.2.4 that I found available and everything works fine. I hope DJI fix this because they have S21 as a compatible phone
2021-4-16
Ralle
Flight distance : 11289 ft
Finland
What items did it change for Mini? Should I upgrade from version 1.2.4 version 1.4.0
2021-4-16
djiuser_bjJCN7L0HMo2
Flight distance : 783061 ft
Ralle Posted at 4-16 22:37
Mit dem Update auf die Vers. 1.4.0 der DJI Fly App scheint sich bei der Belichtungssteuerung was geändert zu haben im Flugmodus zumindest bei der Mavic Mini. Dort gibt's jetzt angezeigt unten rechts auf dem angeschlossen Handy-Display entweder "Auto" oder "Pro". Das Schloss-Symbol (geöffnet od. geschlossen) ist verschwunden. Das finde ich extrem bedauerlich, denn damit hatte ich ausschließlich gearbeitet. Die Drohne so gedreht, daß die Belichtung einem guten Ausgleich zw. hell u. dunkel bzw. mit der Sonne und im Gegenlicht entsprach und diese Einstellung dann mit dem Schloß einfach eingefroren. So paßte es für die gesamte Sequenz z.B. bei einer Umrundung. Wie soll man das jetzt machen in dem neuen Pro-Modus?
Ich fand es außerordentlich hilfreich, im alten Auto-Modus (u. Schloßsymbol geöffnet) bei entsprechender Drehung und damit Stellung der Drohnenkamera zum Licht, die Belichtungseinstellungen dann einfach festzustellen, in dem man beim Schloßsymbol auf schließen ging.
2021-4-17
Ralle
Finland
djiuser_bjJCN7L0HMo2 Posted at 4-17 00:43
Mit dem Update auf die Vers. 1.4.0 der DJI Fly App scheint sich bei der Belichtungssteuerung was geändert zu haben im Flugmodus zumindest bei der Mavic Mini. Dort gibt's jetzt angezeigt unten rechts auf dem angeschlossen Handy-Display entweder "Auto" oder "ro". Das Schloss-Symbol (geöffnet od. geschlossen) ist verschwunden. Das finde ich extrem bedauerlich, denn damit hatte ich ausschließlich gearbeitet. Die Drohne so gedreht, daß die Belichtung einem guten Ausgleich zw. hell u. dunkel bzw. mit der Sonne und im Gegenlicht entsprach und diese Einstellung dann mit dem Schloß einfach eingefroren. So paßte es für die gesamte Sequenz z.B. bei einer Umrundung. Wie soll man das jetzt machen in dem neuen Pro-Modus?
Danke für die Antwort
2021-4-17
jonny007
Obwohl ich eigentlich alles andere als scharf auf Updates bin, weil sich bei der Mini 1 eh nix tut, hab ichs jetzt doch mal installiert (hatte vorher 1.2.2). Der Zugriff auf die Kamereinstellungen sind jetzt unten und schneller erreichbar. Belichtung sperren (im Bildmodus) geht, natürlich nur bei Einstellung Auto. Einfach ins Bild tippen zur Auswahl der Belichtung und nochmal länger in den Kreis tippen zum sperren. Wieder lösen geht genauso. Gibts auch deutsche Videos dazu, in Youtube mit "Flyapp 1.4.0 deutsch" suchen.
2021-4-18
Ralle
Finland
2021-4-18
djiuser_1oS7PZ2UjB62
Flight distance : 640709 ft
Argentina
A mi me pasó lo mismo, con mi  S 21 ( Pantalla negra). Podrías indicarme desde donde descargar la versión anterior?  Ahora no puedo volar mi Mini, y desde el soporte  DJI me contestaron que busque en Google!
Muchas gracias por su amabilidad!
2021-4-19
fansb1b465dc
Flight distance : 94672 ft
Same issue for me. Exynos 2100 CPU S21 black screen with v1.4 i contacted support chat to ask them to raise as an issue.
V1.3 works fine.
2021-4-19
djiuser_ZQE6Kf3LDtwr
Flight distance : 30128 ft
The screen is black! samsuns s21 exynos cpu ... software dji fly 1.4 is not functional. not possible to go back to 1.3x apk because dji does not offer the download link for this version ...
2021-4-20
fansb1b465dc
Here you go. V1.3 is now available on apkmirror
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-fly/
2021-4-20
sonyp900
Greece
fansb1b465dc Posted at 4-19 22:45
V1.3 works fine.
It's very sad to have this issue with Samsung's flagship phone.....
2021-4-22
djiuser_I0uZt0G1i1ug
I have the same problem on my S21. Now I installed an older app-version (1.3.) and the problem is solved
2021-4-22
nyc2rsmnt
Flight distance : 154 ft
Just spoke with support. The issue will be resolved in V1.4.2 of the software.
See this thread:
https://forum.dji.com/forum.php? ... D712%26typeid%3D712
Also a link to an older version of the software that still works :
https://drive.google.com/file/d/111N7W1DR0gYC5biMTGJUZam-d3TAh9Ep/view?usp=sharing
2021-4-22
BVP Drone 1
Flight distance : 823497 ft
I am very new to this, but I have had constant problems trying to use the S21 with the kit controller for the Mavic 2 Pro for the last two weeks. Constantly losing connection Constantly not being able to connect to the drone. I ordered a SC last week and took it out this morning and it was like magic, zero problems at all connecting.
The whole process of mounting,  using and connecting the S21 to the drone makes it look like a bunch of amateurs designed the kit controller.
2021-4-22
djiuser_ds8Pz1fgHpEx
I have a S21 Ultra and since I updated to v 1.4, I am getting a black screen instead of the live stream
2021-4-22
nyc2rsmnt Posted at 4-22 09:54
The big question is when. I found this issue a week ago. For a company as big as DJI it should've been solved in hours
2021-4-22
djiuser_ZlrNMnJuVpZG
Flight distance : 1301027 ft
I am also having the same issue on my Galaxy S21 Ultra, Snapdragon 888, Android 11. I had no issues on my previous Note 10 Plus.
Will confirm, v1.3.0 works fine, from the link in the previous post.
2021-4-22
djiuser_8fLYo5fiNwPj
djiuser_ZlrNMnJuVpZG Posted at 4-22 14:42
Same issue here with S21 Ultra (Exynos) and Mavic Mini. Will try to install 1.3.0 today.
Edit: I have just been in contact with support. Version 1.4.2 (where the problem is fixed) is supposed to come already end of April/beginning of May
2021-4-23
SpyderUnderH2O
Same issue S21 Ultra Snapdragon processor, Android 11 ... DOES NOT WORK!!!,  Unacceptable!! If I didn't have an iPad my drone would now be useless.  I should not have to backlevel my software to make it work.
2021-4-23
djiuser_D8PiF4KFlqCl
Flight distance : 24948 ft
Norway
Hi,
I have the same issue. Not S21 ultra. But s21+1.3.0 works fine.
European version of the s21+
2021-4-23
spanzetta
Flight distance : 1124738 ft
The same here.. S21 Ultra...
Only black screen..
2021-4-24
spanzetta Posted at 4-24 01:43
Only black screen..
Go Back to 1.3.0 of the DJI Fly App and wait for the 1.4.2 Update.
2021-4-24
Neil Bland
Flight distance : 37854 ft
I too have similar issue, Samsung galaxy s21 5g, dji fly app 1.4.0.
2021-4-24
fansb1b465dc Posted at 4-20 22:17
Merci !! Very good
2021-4-29
djiuser_iHDCZGgsyMw8
Flight distance : 158497 ft
Samsung s21 5g and I have same issue with a black screen but if I take a shot it shows photo was taken...I just can't see anything whilst flying. Please fix this ASAP
2021-5-1
3Recon
Flight distance : 4175541 ft
DowntownRDB,  I've been neglecting my  little Mini and yes I've ben playing with my favorite Air2 with 1.4.0. When I went to fly Mini I had a Black screen on my S21 Ultra. I 'd rather not start rolling back to fly my Mini. What happened to one software for all Mini, Mini2, Air2 and Air2s and FPV?
2021-5-2
DowntownRDB
3Recon Posted at 5-2 10:57
On a couple of previous DJI Fly App versions people using a Samsung phone with an Exynos process (some on S10, some on S20, and Note 20, etc.) were experiencing black screens whereas those using Snapdragon processors were not being effected.
DJI never aired what the issue was but was able to fix it each time.  In reading through the forums it's quite evident that DJI prefers the use of Apple products over any Android OS product.  iOS users got the Fly App update before the Android version several times.  The DJI FPV Flight simulator was designed for iOS and still not available for Android.
2021-5-3
Osmoderma_2020
Same problem. I switched from Note 9 to S21U (Exynos) and screen remains black. App. ver 1.4.0. Drone by itself takes fotos.
2021-5-3
Osmoderma_2020
djiuser_8fLYo5fiNwPj Posted at 4-24 10:42
Thanks a lot!!! ver 1.3.0 works so far (not fully tested yet...) on my S21U (Exynos). I really hope they will fix it
2021-5-3
3Recon
DowntownRDB Posted at 5-3 03:17
Hey DowbtownRDB  I also have the snapdragon chipset, even though Samsung's  Exynos chipset is starting to out preform or equal the snapdragon,
Any way I have been strictly flying my Air2 with phone  with a couple Burps but no black screens and I come back over to fly  my mini. If I could just walk over pick up and go for a quick flight out back. both the s21Ultra and my Galaxy Tab s3 fly well with the Air2.
I may have to do a complete app/software reinstall, it is the ideal size.
2021-5-3
Wanabe Pilot
Flight distance : 3261 ft
Norfolk Island
Same problem for my Mini using a S21 Plus
2021-5-4
fabga64
i have the same problem with mavic mini e galaxy s21 standard
2021-5-10
djiuser_SdspcuPX0SzG
Same issue here Samsung s21 Canada model app 1.4 no image.any news on a fix?
2021-5-18
spanzetta
1.4.2 just released (it should fix the issue)
Direct link
https://service-adhoc.dji.com/download/app/android/3b03cb95-bc4b-4b62-b4ab-9cf977d77309
2021-5-19
sonyp900
Greece
Whoever has the chance to install 1.4.2 and try, please let us know.
2021-5-19
sonyp900
Greece
spanzetta Posted at 5-19 00:24
Direct link
We all hope for this fix. So upsetting to have this issue with Samsung's flagship phone
2021-5-19
spanzetta
I just checked and it works..
S21 Ultra 5G ..
2021-5-19
12Next >
