Video Glitch 200m away
809 7 2021-4-16
Suren
Flight distance : 13498560 ft
New Zealand
Hey Guys, so i did a small test flight to check the drone and found that 200m away the video on my screen was glitchy. below is the 2 videos, 1 from SD and the other from the phone, also when i tried to zoom in while in video mode using 2 fingers it kept going in active track-am i doing something wrong?
2021-4-16
Suren
New Zealand
2021-4-16
Suren
New Zealand
I must say though that this is an amazing little drone with some cool features. The video above is unedited and directly from the SD Card.
2021-4-16
Bigplumbs
Flight distance : 620164 ft
You don’t zoom with your fingers you press the fn button and use the gimbal wheel
What phone or screen are you using re the glitching
2021-4-16
Suren
New Zealand
Bigplumbs Posted at 4-16 22:37
Using iPhone 12 Pro Max
2021-4-17
DAFlys
They added pinch zoom in 1.4 release.
2021-4-17
hallmark007
Flight distance : 10017858 ft
Suren Posted at 4-16 18:30
https://youtu.be/Mm2Ra91iuN0
The zoom is more than likely something to do with screen, a bigplumps said use wheel for zoom set f button to zoom click it then use wheel.
The glitch just looks like video interference could be anything in you area that might interfere. Keep testing footage looked very sharp and clear.
2021-4-17
Suren
New Zealand
hallmark007 Posted at 4-17 01:42
Yeah, I used the fn and wheel this morning worked much better. The glitch was not as evident this morning but I did a firmware refresh before flying so that could have fixed that.
2021-4-17
