M300RTK Waypoint Turns Without Stopping
1959 2 2021-4-18
fans5b25584c
Flight distance : 24012 ft
Does anyone know a way to geterate waypoint missions with turns that don't stop and start?
Its a waste of battery energy and time, and watching though the camera lens, the jerking motion on the equipment seems substantial.
Unfotunately, setting a waypoint as a "Curved Route, Aircraft Continues" results in the loopy, spirograph routes, as attached.
The Phantom series has the capability of making smoth 90 degree turns with a radius of about 1 meter, without stopping or getting off the mapping grid.
Any way to do that on a M300RTK?
Thanks in advance
2021-4-18
djiuser_WkPllUTqtcB1
Turkey
I am also looking for a straight foward method for my waypoint mission plans. Have you tried inserting several more waypoints between existing ones? Also coordinated turn skips waypoints" setting may help.
2021-5-18
fans5b25584c
"Coordinated Turns" is the solution
If you export the KML you can also edit the turn radius
This type of turn is a smooth turn without stopping
2021-5-18
