Front LED light stuck on disable?
705 14 2021-4-18
Danibis719
Flight distance : 392995 ft
My mini 2 front LED light is stuck disabled. I can select different light patterns but as soon as I exit the settings it goes back to disable. I have the latest updates. Any ideas?
2021-4-18
DJI Stephen
Super Moderator
Hello there Danibis719. I am sorry for the trouble this has caused and thank you for reaching out. Are you able to post a short sample video showing the said issue for us to see and assist you further. In addition I will post the DJI Mini 2 Front LED Status as well. Thank you.
2021-4-18
DAFlys
Flight distance : 5907336 ft
Are you running 1.4.0 of the Fly app?
2021-4-19
Danibis719
DAFlys Posted at 4-19 00:38
Fly app on apple
2021-4-20
djiuser_5Gg14kGfAxro
My brand new (today 07.08.2021) mini 2 front led light also does nothing I also have the latest firmware I can change the colour in the settings but no light on at all  did you get any reason or fix advice
Cheers sean
2021-8-7
Danibis719
djiuser_5Gg14kGfAxro Posted at 8-7 10:33
Cheers sean
I did get it working. I can't remember what it was that fixes it lol. Something simple. Resetting the settings or ....let me think about what it was
2021-8-7
Danibis719
I don't remember. Try turning the light off in the head set then restarting the headset with the power button but leave the drone powered on
2021-8-7
djiuser_7rq5VZloew16
United Arab Emirates
I'm facing the same issue. Front LED light doesn't change any another color other than white.. and I have notived when I exit the dji fly app and get back into it the  front LED light option is disabled..
2021-10-13
Zorbat
Front LED not configurable is due to a bug in the DJI Fly app 1.4.12 (both initial and current build 1410
My workaround is to take my second phone on which DJI Fly app 1.4.8 Build 1185 is installed, configure the Front LED.
2021-10-13
Johnny_J
Austria
DJI Stephen Posted at 4-18 21:51
[view_image]
A "sample video" of a LED that is not blinking?????
2021-10-13
djiuser_eqgpNh1HOKYn
Hi I'm having the same problem, my mini 2 front led is stuck on pink solid after updating, Android app, can't change this sucks ,it worked fine before the new update dji please fix I have the Galaxy fold 3 2000 dollars,  please cater to Android users,  Apple
2021-10-29
Cheers sean
I have the same problem, my mini 2 is stuck pink light, after updating, worked fine before update, dji don't like Android.    Only Apple,  witch sux overheating junk.
2021-10-29
[view_image]
After updating firmware  my mini 2 is stuck on pink solid horrible, i can't change, this is Android update ,please help,  i would rather have stock white pulsating,  then solid pink......please help  10 31 21.....i want my old version when everything works like it should.
2021-10-31
djiuser_mOT5uMbeMiCM
Bulgaria
After the last update, I can't change the headlight to the color I want. It's my drone DJI mini2.Help. rather, release the new update and fix this problem
2021-11-1
Zorbat
Front LED change works using DJI Fly App 1.5.0 Build 1855 for Android
2021-11-17
