screen flickering
6322 13 2021-4-20
kosmitsop
Flight distance : 275007 ft
Greece
hi,
i have a problem when i connect my mavic air 2 with my phone and controller.
as you can see in the video attached, my phone screen is flickering even if i has my drone landed or on air.
Is there anybody know how can i fix it?
2021-4-20
VanzPix
Flight distance : 229672 ft
Hello I'll give you a DJI style answer ;) have you tried with another phone to see if the problem persists
2021-4-20
kosmitsop
Greece
VanzPix Posted at 4-20 02:08
yes, of course.. with all updates on fly app, remote controller, drone firmware.
and with another cable..
2021-4-20
DJI Stephen
Hello there kosmitsop. I am sorry for the trouble this has caused and thank you for reaching out. May we know what is the model of the mobile device you are using please and can you please try to uninstall and reinstall the DJI Fly application for us to be able to isolate the said issue? In addition, please try to enable the anti-flicker on the said application as well. Thank you.
2021-4-20
fans8685029d
Greece
DJI Stephen Posted at 4-20 02:22
Thank you for your answer. I use an iPhone 12 Pro Max and a Samsung A21.
I have already installed and uninstalled my DJI Fly Application. I turned off auto option on Anti-Flicker and switched on 60hz or 50hz but the problem still remains
2021-4-20
JimDandy
Flight distance : 144649 ft
fans8685029d Posted at 4-20 02:35
Worth a try here, Re-install the fw on the MA2 using dji assistant 2.
2021-4-20
djiuser_mqY2wZR4XBQS
Flight distance : 2349 ft
Having same issue
2021-6-30
MA2 Steve
Flight distance : 100656 ft
Has there been a fix worked out for this yet?
I'm getting the same problem now
2021-7-15
djiuser_jlh87NLV4iN5
Flight distance : 12533 ft
Same issue. Any resolution?
2021-9-11
kyalami
Flight distance : 17352513 ft
Sweden
That to me looks like a bad connection somewhere. Don't know where though. Does it look the same way on the SD card when filming?
2021-9-12
fans8685029d
Greece
I sent my drone to DJI and they replaced the aircraft. This is NOT  a problem on the firmware or the installation. It’s a hardware problem and cannot be solved.
I suggest, who ever else have this same problem with your mavic air 2, to send the aircraft to DJI service. They will replace it.
2021-9-12
kyalami
Sweden
fans8685029d Posted at 9-12 02:14
Great news that you get a new drone. I thought it had to do with the drone, that's why I asked if it also was on the SD card.
2021-9-12
djiuser_SbOHB2EJlBRo
Having the same issue. I took the drone for its first flight and before  using the entire first battery it started flickering. Now I recharged the battery, reinstalled app, updated firmware and app and it seems to gotten worse and it also causes the tracking feature to lose the subject it is following very easily.
2021-10-10
Onverg
Trinidad and Tobago
I have the same issue now. It is flickering even I am not recording or even before I take off. Anybody found a resolution to this without having to send it in? My drone is out of warranty.
2022-11-25
