Set the DJI FPV to FCC
11876 16 2021-4-20
crash1sttime
Flight distance : 1454524 ft
https://m.youtube.com/watch?v=oj93Y13JECw
2021-4-20
DAFlys
Thanks for sharing.
2021-4-21
Buzzyone
Flight distance : 4698707 ft
Made no difference for me!
2021-4-21
DJI Stephen
Hello there. Good day and thank you for sharing this link and these information here at DJI Forum. Just a reminder that DJI do not recommend you to modify your DJI FPV or any of its components. There is a  possibility that these modification will work however, since it's not tested by DJI we cannot guaranteed the reliability of the said battery when in use. In addition, modifying your DJI drone might cause damage and can void the warranty of the said DJI Drone as well. Thank you for your understanding and fly safe always.
2021-4-21
tomekyo
Flight distance : 3226991 ft
You can do it here for free:
https://b3yond.d3vl.com/
2021-4-21
DowntownRDB
Flight distance : 1722 ft
Nice find.
2021-4-21
DowntownRDB
tomekyo Posted at 4-21 03:04
Thanks for sharing.
2021-4-21
Buzzyone
In my opinion it depends more on your flight location rather than increasing power, I have tested both available hacks using the same parameters and for my flight location, open countryside, it made little diffrence. The increased power is present, as confirmed with an ImmersionRC RF power meter, but the fliging environment has an influence on range too.
2021-4-21
amitgv1
Flight distance : 1032493 ft
I tested the Android app. The change is dramatic
2021-4-21
tomekyo
Buzzyone Posted at 4-21 05:55
Also, no difference after testing.
your testing is inconclusive so please change your statements to opinions or buy a power meter to convince yourself. This is indeed working and if you don't stop to spread BS I will make a video and post as reaction to all of your posts
2021-4-21
Buzzyone
tomekyo Posted at 4-21 12:00
No problem, it may not have come across as my opinion, but thats all it was. I have confirmed the power using a power meter and there is more of it, but, in my opinion, flying two drones, not at the same time, one with CE one with FCC in my location I saw very little difference.
2021-4-22
amitgv1
Buzzyone Posted at 4-22 00:54
Really strange. I got around 4 times longer distance in FCC mode. I live in Berlin. In places that I can run to around 600 meters I can fly to around 2.6 kilometer using FCC hack
2021-4-22
Buzzyone
amitgv1 Posted at 4-22 10:43
I found that 2.5km was about the limit out in open countryside with with or without FCC.
2021-4-22
djiuser_y3gdwQnotffm
Wich hack do you use?
2021-12-19
djiuser_cBCSy1mQ2Nin
Flight distance : 7326 ft
tomekyo Posted at 2021-4-21 03:04
Hello, does it make any confirmation? Because i did the process and at the end it says: OK but thats it.
2022-1-22
Disturbed
I tried the B3YOND unlock patch and the result was a sensor signal error and imu was not able to calibrate, it got stuck at 95%.  After i connected the drone again to the fly app i could re-calibrate IMU again and fly.
2022-1-28
Sanpanza
Flight distance : 539019 ft
video is private. No go.
3-29 11:16
