Mavic 2 Pro/Zoom New Firmware Released
123Next >
42470 92 2021-4-21
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2021.04.22
  • Aircraft Firmware: v01.00.0770
  • Remote Controller Firmware: V01.00.0770
  • DJI GO 4 App iOS: v4.3.42
  • DJI GO 4 App Android: v4.3.42
What’s New?
  • Fixed occasional issue: battery could not be charged when the battery level was low.
Notes:
  • Restart the aircraft and remote controller after the update is complete.
  • Note that the update may reset various main controller settings, such as the RTH altitude and the maximum flight distance, to default settings. Before updating, take note of your preferred DJI GO 4 settings, and readjust them after the update.
  • If the update fails, restart aircraft, remote controller, and DJI GO 4 or DJI Assistant 2 for Mavic, and retry.
2021-4-21
Suren
Flight distance : 13425892 ft
New Zealand
When I saw this I thought maybe the Mavic got some nice feature upgrades but No
2021-4-21
JohnDG
Flight distance : 1097270 ft
Malaysia
do not forget to update all your batteries, because this is mainly a battery firmware update. Every battery has to be updated.
After updating your craft with one battery, shut it down. Put in your next battery and start your craft. A message of unconsistant firmware will occur in the DJI Go4 app. Slide to update the battery. Do this before you fly your craft.
2021-4-22
Monkey007
Flight distance : 73775046 ft
Suren Posted at 4-21 20:45
It seems the 'nice feature upgrades' are only exclusive to the new models from DJI, for a long time now.
2021-4-22
fansaf28829f
Flight distance : 16267723 ft
Switzerland
offensichtlich war dazwischen auch noch ein Firmwareupdate, wo es mir nie angezeigt hat ....Date: 2020.11.12
Aircraft Firmware: v01.00.0720
Remote Controller Firmware: V01.00.0640
What’s New?
 Optimized RTH performance.
 Optimized prompt when experiencing GPS interference.
 Fixed occasional issue: when flying at high altitude, the altitude displayed was incorrect.
 Fixed occasional issue: battery could not be charged when the battery level was low.
2021-4-22
Suren
New Zealand
Monkey007 Posted at 4-22 03:22
Yup, not that I will complain but one can always have hope the M2Z will get some better features
2021-4-22
Monkey007
Suren Posted at 4-22 10:01
Yes, give us focus track for our Mavic2, or give us the Mavic3 quick please DJI!!!
2021-4-22
djiuser_m5MoG1V1mqpU
Finland
Hello, I have a problem. I updated yesterday my drone and controller (mavic 2 pro) and now my DJI Go 4 app does not work, and it is not connect with controller. So I cannot go to the see my videos or fly . What should I do ?
2021-4-23
lamproslyr
Greece
djiuser_m5MoG1V1mqpU Posted at 4-23 00:10
the same problem with me . i have a iphone 12 mini
2021-4-23
FatherXmas
Flight distance : 4058619 ft
I updated my M2P and M2Z both today. If I go into settings then click the battery icon, the number of days until discharge appears to be missing. Was it moved or has DJI decided we can't set it ourselves? By the way, I opened Pilot, it's still there. DJI changed the 10 days I had set to 2 days. Fortunately, Pilot let me change it back to 10.
Edit: It appears this is a crytalsky issue. When I use my iPad Mini 4 or TRIPLTEK, all is well.
2021-4-23
Gordon G
Flight distance : 6813868 ft
I did the 200+MB M2P upgrade this morning and then went to fly, only to discover the top speed in S mode is now only the same as in P mode, which was rather disappointing.
2021-4-23
Gordon G
Additionally, I've just found that the flight speeds in T mode are also the same as in P mode, rather than the much slower speeds that is supposed to do in that mode. I wonder when these errors will be fixed?
All my batteries have been updated, so it is not related to that.
2021-4-23
Gelert
Flight distance : 2063238 ft
Gordon G Posted at 4-23 23:15
Have a look in the "Main Controller Settings" in the Go 4 app. You may find that the Multiple Flight Modes option is switched off - worth a try
2021-4-24
CanonMax
Flight distance : 8953215 ft
Gelert Posted at 4-24 04:43
Indeed... after an update I always check ALL settings I use and I noticed that "Muliple FLight Modes" was reset... Now I hope you could help the people with this problem...
Take care and DJI-safe!
Max
2021-4-24
djiuser_l6s5wl0Zx5pb
Not sure if this is the right place for this, but I'm unable to connect to my Mavic Pro 2 after this update. I can fly it with the controller but I'm getting a "Gimbal disconnected" message and can't connect the app to the drone. Just bought the Mavic 2 Pro two days ago and can't get this figured out.
2021-4-24
Gelert
djiuser_l6s5wl0Zx5pb Posted at 4-24 08:41
Which phone/tablet are you using ??  Have you tried a different cable between the controller and phone/tablet ?? I always connect the controller via the bottom USB-A socket - the connector on the left side of the controller can be a little iffy.
2021-4-24
Gelert Posted at 4-24 08:53
I have an iPhone 12. I'll give the USB-A socket a try and see if that helps. It sent me through the activation process no problem, but after the firmware update it greyed out the "link to aircraft" button. The gimbal situation feels like a whole different situation. Maybe a hardware defect, unfortunately. I just bought it new from a Best Buy two days ago.
2021-4-24
djiuser_l6s5wl0Zx5pb Posted at 4-24 08:57
No luck with the USB-A slot.
2021-4-24
FloridaNext
Flight distance : 62320 ft
djiuser_l6s5wl0Zx5pb Posted at 4-24 09:10
Did it all work before the update?
2021-4-24
FloridaNext Posted at 4-24 09:22
I never got the chance to get the camera up and running before the update. This was my first experience opening the app and connecting the drone. Then I updated it before going any further and that's where I'm at now.
1. Bought drone, assembled, charged battery and controller.
2. Did initial drone connection (i.e. naming, stick calibration, etc.)
3. Updated firmware as that was the first prompt I saw after initial setup.
4. Update applied and can no longer connect the app to the drone.
2021-4-24
FloridaNext
djiuser_l6s5wl0Zx5pb Posted at 4-24 09:34
Can you try a different phone? Because the iPhone 12 is NOT in their compatibility list.
Look here: https://www.dji.com/de/downloads/djiapp/dji-go-4
2021-4-24
Gordon G
Thanks, yes that was the issue!  I went for a quick flight after fixing that and it was all good
When doing these FW upgrades surely it wouldn't be too difficult for the process to save your settings, install upgrade and then re-apply the setings, rather than set everything back to default? Plenty of phone apps manage to do that.
2021-4-24
Gelert
Gordon G Posted at 4-24 14:40
Glad you got it sorted
Fully agree that FW or app updates shouldn't change settings but it seems to happen quite often with DJI products. In fact, its so common, DJI recommend checking post update settings for any changes which worryingly suggests that even DJI don't know what settings may change
2021-4-24
Gelert
2021-4-24
ronnyronnyroe.com
Flight distance : 768143 ft
Sweden
My Problem:
I have an iPhone 12 Pro Max that I have used without a problem with DJI GO 4 and my Mavic Pro 2 until now. I made the update, everything went fine. After restart of Drone and Controller the controller finds the drone BUT in the app it now says "Disconnected" to the drone although the controller has found the drone.
I have restarted the drone, the controller and the iPhone but still no luck to connect the app, it keep saying "disconnected". Any ideas?
2021-4-25
Baker1969
I had the same issue when I connected my new phone: Samsung 21 Ultra. Would not connect to drone from USB port. I connected via the side micro usb. I got a connection, but no video?? I had to revert back to old phone.  No need.  Hopefully an update could resolve this.
2021-4-25
Ronny Roe
Sweden
Baker1969 Posted at 4-25 01:55
I tested with my iPad and that worked fine. So the issue is with my iPhone 12 Pro Max, that is for sure. Hopefully DJI will fix this soon or at least explain how to downgrade from this update until it is fixed.
[SOLVED]: Completely turning off the iPhone, waiting 2-3 seconds and then turning it on again fixed it.
2021-4-25
scoble08
Flight distance : 4327592 ft
ronnyronnyroe.com Posted at 4-25 01:40
My Problem:
Did you try Re-Binding drone to remote controller?
2021-4-25
Ronny Roe
Sweden
scoble08 Posted at 4-25 08:18
Well, the thing is that the RC talks without a problem to the drone, so there is no problem between drone and RC, it is the iPhone 12 Pro Max that suddenly in DJI GO 4 app says "disconnected device" even if the USB cable to the RC is connected. This stopped working at the exact moment I applied the new update.
Anyway, stranger things has happened, so I tried your advice. In the app it doesn't matter if I try alternative "Linking Remote Controller" because the app can't communicate with the RC. But I did press the Re-linking button on the drone, and had it re-connect with the RC. But no dice there.
And as I said, I can use my older iPad with DJI GO 4 and it works without a problem with same cable to the RC. So it is definitively something with the combo of this new update and iPhone 12 and current version of DJI GO 4 that creates the problem.
2021-4-25
Ronny Roe
Sweden
Ronny Roe Posted at 4-25 10:20
Solved!
What I hadn't tried was to completely turn off the iPhone and wait a couple of seconds and then turn it on again. Now it works as it should. I am happy and hope that it helps if someone else has the same problem with an iPhone. If it doesn't connect: Turn it fully off and wait 2-3 seconds before turning it on again.
2021-4-25
DAFlys
Cheers for the tips guys,  reporting controller and phone restored the iPhone 12 connection.  No idea why but hey ho.
2021-4-26
Drycatoh
Flight distance : 1172723 ft
Still hoping for that 360 panorama mode using the Super Resolution feature on M2Z... Maybe one day... If DJI still hears us
Even if it's not automatically assembled (because it's probably super heavy on the main CPU of the drone), it would be awesome just if it would be able to take the pictures by itself!
2021-4-26
TrippleDelta
Flight distance : 2228182 ft
Belgium
FatherXmas Posted at 4-23 16:26
When hiking with my drone I like to know when the batteries will start discharge.
2021-4-27
gnirtS
Flight distance : 5712575 ft
Its still there on mine although all batteries went to 2 days and i had to manually reset them (on SC).
One thing i think has changes is the red "max motor speed reached" which you usually trigger climbing full power and flying forward into the appears to have been replaced by a yellow "propulsion power has been limited to protect battery" instead.
2021-4-27
Joe Malenfant
I keep failing update code 0x100000 any ideas ?
2021-4-27
alloffroad
Flight distance : 6339409 ft
no update show up for me using the Smart Remote
2021-4-27
son_of_a_hutch
Flight distance : 10472 ft
So that explains my brand new dead battery then...
If anyone at DJI comes through here: I've updated my two remaining batteries but I've had no news on the support ticket I opened on April 19th for the battery that died. Ticket is marked as "awaiting reception" but I haven't received the e-mail that I was supposed to receive within two days. Any idea what's happening?
Thanks,
Alan
2021-4-29
djiuser_FxVd8G9xxGnF
Iran
I wish to add d-log video capture to quick shot to m2p in new update but...
2021-4-30
AntDX316
Flight distance : 3394731 ft
djiuser_FxVd8G9xxGnF Posted at 4-30 14:01
D-Log isn't even good..
2021-5-1
AntDX316
TrippleDelta Posted at 4-27 00:50
Is it worth bringing the drone on a hike?
2021-5-1
123Next >
