Problem: Image stabilization while Powerloop
2118 6 2021-4-22
J_De_Ese
Flight distance : 4201250 ft
Hi,
I just wanted to share with you an experience I had with the drone footage of the DJI FPV.
I was training with the DJI FPV on a beach and I was doing powerloops and other acro manouvers, and I thought the movements were more or less clean (as seen on the googles) but then when I checked the drone footage I realized some weird camera movements.
I think this has to do with the camera stabilization. Did that happen to any of you guys? Do you know how to fix this problem with the drone footage?
Here is the video of the issue:
YT video of Issue
(https://www.youtube.com/watch?v=iC10fltudjs)
Thank you very much for your help.
Looking forward to hearing from you, guys
2021-4-22
CoreyB10
Flight distance : 1665023 ft
Can't say i have noticed it with mine at all. Flown it everyday since it came last Monday too.
2021-4-23
FrootWhoopz
Flight distance : 253832 ft
Yea, I think it may be the "Image Roll Correction" option, I have not had it on yet and probably wont. Check if that option is on, try turning it off, you don't need that option when you want to do freestyle anyway imo, perhaps in N mode when trying to get levelled out footage.
2021-4-23
glides
Flight distance : 279203 ft
EIS is safe to use in manual mode
Image Roll Correction should be avoided in manual mode and used really only in normal mode to imitate a more traditional 'mavic' look on the recording.
I've also heard that the distortion correction has a bit of roll correction in it as well, but I've not seen those jumps with EIS and Distortion correction on - I've only seen them with  Image Roll Correction.
2021-4-23
tomekyo
Flight distance : 3226991 ft
is this a video from your goggles or the craft itself? I had the same issue but only on the goggles. It happens at the moment the transmission has been lost for a split second ...
2021-4-23
J_De_Ese
Hi everyone, and thanks for your responses.
I checked and both "EIS" and "Image Roll Correction" were turned on.
So I think I will first test disable the "Image Roll Correction" and see what happens.
The video is both from the craft and goggles (the smaller video is from the goggles)
2021-4-24
frankymusik
Flight distance : 27904331 ft
glides Posted at 4-23 10:57
2021-4-24
