JJB*
Flight distance : 12260774 ft
Huginn Kenningar Posted at 4-24 02:24
If you listen to the video as soon as the "bipbipbip" from the sensors stops the drone flights straight. To fly close to the ground and maintain low altitude you need to deactivate the sensors.
In normal mode and APAS the drone will automatically move away from objects/ground.
Hi
few comments on your post.
If you listen to the video as soon as the "bipbipbip" from the sensors stops the drone flights straight. To fly close to the ground and maintain low altitude you need to deactivate the sensors.Beeps are from the rear sensor, as in the front of the drone is 'nothing' at that height.
No need to deactive OA low flying, as long as there are no obstacles in the way drone will fly forward at the same low height.
away from ground only if the bottom sensor is sensing 0.5 meters, so slow flying uphill will raise the craft.
Lowering height by RC down input is possible to 0.5 meter, after that a force landing will be initiated.
Away from objects front or rear ; true craft will raise height or fly around the obstacle.
In tripod mode although APAS is not working (just brakes), down sensors will keep a distance from the ground.
see before
If you deactivate the sensor asistance, sensor will still beep and the orange will appear in the screen, but the drone won't do anything to modify the trajectory. Also in sports mode all sensors are deactivated (all except the bottom ones? didn't try to fly in sports at low altitude XD).
Bottom sensor is not deactivated by disabling the OA.
If you want the drone to move straight at low altitude go to the pilot assistance menu and instead of APAS/brake, select sensors off. From there the plane will show you the ornage bars and beep, but won't interfere with the commands, so you can do a super close ground shot, just above the tall grass, for example. Just remember to reactivate them afterwards
see before, true if you want to fly real close to objects or fly through tall grass.....
Cheers
JJB
