Spark: gesture mode problems
2524 6 2021-4-24
flygirl72
After being in storage for 9 months I fired up my Spark. Everything works fine except for gesture mode. It's activated in the Go 4 app, but there's no icon on the app screen. When I try a palm launch the red lights blink a couple times though the camera doesn't do it's usual scanning. The Spark has the lastest firmware and I tried reinstalling the Go 4 app. Thanks.
2021-4-24
DJI Gamora
Hi, flygirl72. Thanks for reaching out and sorry to read about the difficulties you're encountering. We suggest checking whether Advanced Gesture Control is enabled under the Visual Navigation Settings. Please also check this Gesture Piloting Tutorial in case you have missed other details.
2021-4-24
flygirl72
DJI Gamora Posted at 4-24 23:34
Thanks for the reply. Gesture mode is on in the menu. I tried refreshing the firmware in assistant 2 to no avail. I wonder if it's the RC, because when I turned it off palm launch worked.
Update: I may have found the problem. The phone I'm using won't connect to the Spark's network.
2021-4-25
Wolferl
Flight distance : 23793 ft
Austria
flygirl72 Posted at 4-25 00:51
Just out of curiosity: which mobile device did not work with yoour Spark?
Could it be your Spark it set to use 5GHz Wifi and your device does not support it?
Cheers,
Wolferl
2021-4-26
flygirl72
Wolferl Posted at 4-26 08:53
I was originally using a samsung note 3 that worked fine since I bought the spark, then switched to a google pixel3 and there was no difference. Still no gesture modes. Also in the channel settings there was no option to change from 5ghz to 2.4ghz. I think it's FU'd. :/
2021-4-29
jasonlseward
For what it’s worth…..I had the same issue and cycling Sport Mode On/Off a few times seemed to solve it.
2022-1-24
shegeek72
jasonlseward Posted at 1-24 16:28
Looks like I never posted the solution. I took it to a DJI authorized dealer and rolling back the firmware to an older version fixed it!
2022-1-24
