thetechnobear
Flight distance : 2804810 ft
the latest version of the DJI Virtual Flight app shows graphs for the rates/exp for M mode
(so, hopefully we can see this in the next DJI FPV firmware ? ... also have profiles which would be awesome on the FPV !)
in virtual flight, it shows exp flattening out the curve , so just like betaflight.
so increasing exp will means less movement in the centre.
exactly how this feels, also depends on centre sensitivity.
to some extent increasing exp, or reducing centre senstivity achieve a similar result
but all 3 parameters are part of an equation, which to some extent affect each other.
(e.g. if you increase your rate, you may find yourself wanting to adjust exp/centre sensitivity)
the new graph in dji virtual flight (or your betaflight graphs) are a good way to see the effect of changing parameters will have.
but of course, ultimately you have to fly a few packs, and feel what works for your style of flying
I've also found as Im improving, Im now increasing the rates, and then re-adusting exp/centre.
upshot is , there are no 'perfect' rates , just ones that suit you.
(though, I think many do thing the intial dji rates are a little twitchy for when you start out)
