DJI fly app
1269 19 4-30 16:24
Gertnby41
I have a sumsung note 20 ultra and I am trying to use the dji fly app but it keeps crashing. I cant even setup my drone. I did manage to ugrade the firmware. Is there anything to fix this or do I need another phone? Help please I am ready to fly!
4-30 16:24
donmusico
Flight distance : 247362 ft
Poland
I've got the same problem on Samsung S21 and Samsung S10. When flying app is often crushing and exiting what cause rhat i don't see what drone do actually.
5-2 01:29
Getnby41
donmusico Posted at 5-2 01:29
I have the dji mini 2.
5-2 05:32
DroneMone
Denmark
I had the same problem today Mini2 and iphone 12Pro - app crashed and froze after firmaware update -  in the end my screen froze as well. I restarted, app, phone and drone - no luck. In the end I could see no other option than to delete the app and reinstall it. Then it worked! But all my flight logs, and edited film projects was gone as I do not sync to DJI cloud due to GPDR issues. What a great day.
5-2 12:11
Vito Magistrale
I just bought  the latest Samsung Galaxy S21 phone and I downloaded the DJI Fly app for Android. It clearly says that the app is compatible with the S21. When I tried flying my Mavic Mini, every thing worked except I had no camera vue. I couldn't see where I was flying , so I had to keep it within vue. I does however record video and pictures but I don't see what I'm recording. Any suggestions as how to clear this problem?
5-3 08:00
donmusico
Poland
Getnby41 Posted at 5-2 05:32
Me too, Dji Mini 2
5-4 05:42
donmusico
Poland
Vito Magistrale Posted at 5-3 08:00
I had this same prpblem 2 days ago, after switching in Sport mode. I thought that drone just flew away but when I landed and restarted app, worked fine.
5-4 05:44
Getnby41
I don't think this forum is for support. I haven't seen any one get help here.
5-4 11:07
Marco Drone
same problem on Android, after update firmware 0300 on Mini2 with FLY 1.4.0, random freeze return video and crash app, exposure block not working, i downgrade firmware 0100 and DJI FLY 1.2.2....Great Job DJI
5-5 07:16
Getnby41
Marco Drone Posted at 5-5 07:16
Thanks for the work around. I will try it if I can find the downgraded files.
5-5 09:06
Marco Drone
Getnby41 Posted at 5-5 09:06
hello, with DJI Assistant not possible, i use software Drone Hacks OSX for downgrade, you can find with Google, there is links for download DJI firmware.
5-5 15:21
Getnby41
Marco Drone Posted at 5-5 15:21
I just bought a used dedicated phone to work. Galaxy S8 from backmarket.com. It works perfect so far.
5-6 17:21
DJI Stephen
Super Moderator
Hello there Gertnby41. I am sorry for the trouble this has caused and thank you for reaching out. Have you tried using a different recommended mobile device to see if the issue will still persist? Upon checking the said mobile devices ( Samsung Note 20 Ultra ) that your are trying to use on the DJI Fly application. I am sorry to say that the said mobile devices are not recommended for the said application. We would suggest using a recommended mobile device for the DJI Fly application for compatibility and reliability purposes. There is a possibility that the Samsung Note 20 Ultra will be able to work on the DJI Fly application. But however, since it's not yet optimized with the said application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Fly application while using it. For reference I will post a link where in you can check the recommended mobile devices for the DJI Fly application ( https://www.dji.com/downloads/djiapp/dji-fly ). Thank you.
5-6 21:26
Marco Drone
DJI Stephen Posted at 5-6 21:26
I'm sorry to contradict you, but the problem is not ours, but DJI's, our smartphones worked correctly up to the version prior to 1.4, you should be more critical when DJI makes mistakes ....
ciao
Marco
5-11 22:46
apkgameoffline
Same issue here, i get suggestion several colleagues to change my phone or upgrade software version. Kindly guide me too
5-16 00:36
Getnby41
I am currently using a used Samsung S8. It works perfect.
5-16 17:19
DJI Stephen
Super Moderator
Getnby41 Posted at 5-16 17:19
Hi there Getnby41. Thank you for the reply and it is good to know that after using a Samsung S8 the said issue has been fixed. Have a safe and a happy flying always.
5-18 00:40
djiuser_cAPvEMxKjo8M
Fuck nfz , mi hack application
5-25 10:42
ponstan
Greece
Hi everybdy
May I ask why in my android dji 1.4.2 fly app advanced gimbal settings are in degrees, for examle pitch speed 20°/s and in other users ''20''. Is there any difference and why does this happen???  My drone is mini 2 and my mobile xiaomi 9 note pro. Thanks in advance.
5-25 14:32
Dr0ne_Enthus1ast
Flight distance : 26368 ft
Having had similar problems on my samsung S7 I freed up memory space by deleting pictures. Once I had 2 GB free memory the installation worked fine.
5-26 11:33
