Obstacle avoidance
965 15 2021-5-1
Surgey
Flight distance : 21234 ft
Is anyone having the same issue or noticed that when you switch from Normal mode to C mode the obstacle  avoidance bypass is turned off and on to brake mode and when switched back to normal mode it has changed from previously set bypass to brake mode?
Air 2s
2021-5-1
DJI Gamora
Hi, Surgey Thanks for reaching out! We'd like to know more about your concern. If you could kindly, please take a flight test and screen record the above phenomenon so we can further check it. Thanks and kindly keep us updated.
You can upload the video on Youtube and upload the link here.
2021-5-2
Surgey
I have tried to upload the screen recording g but doesn’t seem to want to work.
2021-5-6
Surgey
https://share.icloud.com/photos/0kcYveFiWIUbrXQn7V9fSyhQQ
2021-5-6
Surgey
DJI Gamora Posted at 5-2 00:16
https://youtu.be/BBhInhBDVjY
2021-5-15
JJB*
Flight distance : 12260774 ft
Surgey Posted at 5-15 00:26
its a private video....
2021-5-15
Surgey
JJB* Posted at 5-15 00:29
https://youtu.be/pFXF4ripKVA
2021-5-15
Surgey
2021-5-15
Surgey
2021-5-15
Surgey
https://youtu.be/-mxMKj_dGMQ
2021-5-15
Calito23
Flight distance : 129793 ft
Argentina
The same thing happens to me
when it is in "cinema" I put the alternative "dodge", when I change it to "normal" it follows the alternative "dodge", but if I go back to "cinema" it goes to the alternative "stop" and it does not allow me to put the alternative "dodge" ", only" brake "and" deactivate "are available. I need to turn off the drone and turn it on again.
2021-5-17
Surgey
I’m sure this isn’t normal????
2021-5-25
Surgey
Calito23 Posted at 5-17 06:49
I have tried this but with the same results no bypass in Cine mode and no obstacle avoidance indicator coloured green. It’s a bit of a worry.
2021-5-25
dotpanic
Flight distance : 567516 ft
Same here :/
2021-6-11
Captain Dangerous
Flight distance : 251762 ft
Yes I get the same thing its very annoying, as you have to switch it back on every time in the settings.
2021-6-11
videoeditman
Flight distance : 6713271 ft
I believe I have the same issue, but just thought it was normal?
2021-6-11
