DJI Stephen
Hello there patdig. Good day and thank you for these information you have posted. After installing the DJI Mini 2's propeller guards, the flight height, flight distance, and maximum flight speed will be limited. Kindly please pay attention to prompts in DJI Fly application. To ensure flight safety, the aircraft's recommended max service ceiling above sea level is 2000 m. Maintain visual line of sight of your aircraft even when using the propeller guards. In addition after installing the propeller guards, hover the aircraft until DJI Fly application indicates that the payload has been detected, and the payload mode is enabled. If the status of the payload mode in DJI Fly application does not match the actual situation, turn it on or off manually in the DJI Fly application. Thank you. |
