Is it possible to adjust the DJI Mini 2 default speed?
15303 25 2021-5-4
Phan Điệp
Vietnam
Hello!
I found that the default speed of the DJI Mini 2 was quite fast (in Cine mode as well), which made my footage look not very cinematic, and In many cases, the drone moves too fast for the subject's speed. Can i adjust the Mini 2's default flight speed to decrease come down? Thanks everyone!
2021-5-4
GaryDoug
Flight distance : 1264639 ft
Are you talking about the forward speed only, or the yaw, roll, and/or camera tilt? You can adjust the those three in the app.
2021-5-4
Phan Điệp
Vietnam
GaryDoug Posted at 5-4 18:45
Yes, I'm talking about the travel speed (forward / backward) of the drone ...
2021-5-4
GaryDoug
Phan Điệp Posted at 5-4 18:47
I don't know of any way to do that other than using a soft touch on the stick ;-)
2021-5-4
Phan Điệp
Vietnam
GaryDoug Posted at 5-4 18:53
Thank you, if I lightly press the stick to fly slowly, it is difficult to keep my hand from shaking...
2021-5-4
DJI Stephen
Hello there Phan Điệp. Good day and thank you for the inquiry. As posted above you can adjust or control the forward and backward speed or your DJI Mini 2 by gentle moving the sticks of your DJI Mini 2 remote controller gently. Thank you.
2021-5-4
Phan Điệp
Vietnam
DJI Stephen Posted at 5-4 20:28
Yes, thank for you answer, have a nice day!
2021-5-4
CemAygun
Flight distance : 810 ft
Philippines
"Cine" mod of Mini 2 is simply broken. If I am not mistaken it is the fastest among the DJI drones for no apparent reason and it is not adjustable. Maybe they will fix it one day, maybe not...
2021-5-4
Phan Điệp
Vietnam
CemAygun Posted at 5-4 22:14
Ha ha, yeah, I really hope they take note of this ...
2021-5-4
DAFlys
As a little hack for slow flying,  rather then push the stick I put thumb on the comb at the base of the stick and use gently pressure there fly slowly,   because your not pushing the  stick you loose the average advantage so it doesn't need to be as gentle as on the sticks.
2021-5-5
Phan Điệp
Vietnam
DAFlys Posted at 5-5 00:02
Yes, that a good idea, i'll try it, thank you
2021-5-5
DAFlys
Phan Điệp Posted at 5-5 00:56
No probs Phan.    Report back how you get on.
2021-5-5
IrishD
Flight distance : 140951 ft
I had an RC heli a few years ago that came with different length thumb-sticks for the controller.
the longer ones gave longer travel (depending on how u hold controls) and so less sensitivity to the controls.
I haven't seen anything on this on here so not sure if this is same with drones ?
2021-5-5
dji_MODDER
Flight distance : 73209 ft
check drone-hacks.com, download the desktop version, you can modify your parameters for free, or go back to stock. (sport mode and normal mode)
2021-5-5
videoeditman
Flight distance : 6713271 ft
see also: https://forum.dji.com/forum.php? ... D766%26typeid%3D766
2021-5-5
Phan Điệp
Vietnam
videoeditman Posted at 5-5 10:04
see also: https://forum.dji.com/forum.php?mod=viewthread&tid=230782&extra=page%3D1%26filter%3Dtypeid%26typeid%3D766%26typeid%3D766
Well, that's probably a common problem for all Mini 2 users, thank you!
2021-5-5
DJI Stephen
Phan Điệp Posted at 5-4 20:31
Hi there Phan Điệp. You are very much welcome and thank you for the reply. If you have any other inquiries or any concerns with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Thank you.
2021-5-5
djiuser_rH3ZPAMJE4A9
Flight distance : 77398 ft
For me The problem is solved if take off in normal mode and change to cinema mode on flight.
Take off in cinema mode does not work.
2021-5-12
relaxosmo
Flight distance : 180604 ft
Hungary
maybe change parameters with dji assistant2?
2021-5-12
Phan Điệp
Vietnam
djiuser_rH3ZPAMJE4A9 Posted at 5-12 08:23
I will try it, thank you very much
2021-5-12
steamship
Flight distance : 229180 ft
Russia
There is another thread on the forum discussing this exact issue, with an excellent video. In short, the mini 2 always takes off in Normal mode irrespective of the switch position, and will continue in Normal mode until the switch is moved to another mode.
Here's a link to that thread: https://forum.dji.com/forum.php? ... p;page=1#pid2481830
2021-5-13
Phan Điệp
Vietnam
steamship Posted at 5-13 04:33
Here's a link to that thread: https://forum.dji.com/forum.php?mod=viewthread&tid=242152&page=1#pid2481830
Oh, this is most likely my problem, I will try taking off in normal mode then switch to cine mode and see if the airspeed slows down again (I really hope this does). ), thank you very much!
2021-5-26
yogi053
Flight distance : 26104915 ft
Phan Điệp Posted at 5-26 00:31
It does fly slower in cine mode as opposed to normal but not by much. Users who are citing this as a problem want it to fly even slower with full stick forward or back.
2021-5-26
djiuser_KnZbxEkLMQ1M
CemAygun Posted at 2021-5-4 22:14
Cine smooth mode is actually the slowest for high speeds put your drone into sports mode on your controller through the little slider in the middle or do it in the app
2023-2-7
fans5f7e04f5
Israel
Here is a little trick i use….
Put on the drone plastic protective cage…
The drone will automaticly discover he is carry an extra unrecognised weight, which automaticly reduce the flight and corners speeds, and give you much more cinematic shots, yes its told that those 3rd part cages are not that safe for drone motors, but see the shots you get with them, and then judge me
3-20 12:24
Shawgod
Flight distance : 5173104 ft
fans5f7e04f5 Posted at 3-20 12:24
Are you talking about the prop guards?
3-24 05:52
