DJI FPV Controller 2 and Motion Controller both will not charge.
12107 23 2021-5-6
harrisrobin
Flight distance : 124111 ft
Hey everyone,
I purchased the DJI FPV Drone and upon opening it yesterday, I noticed that I was not able to charge any of the controllers (motion controller or remote controller).
I troubleshooted it by trying various cables and testing these cables on my previous DJI controllers from my mini2, the cables themselves worked but they would not charge any of the DJI FPV controllers (motion and regular controller).
Has anyone ever faced this issue? I am completely flabbergasted that both controllers won't charge at all. I can't explain it.
Here is a video that shows both controllers not responding at all to being plugged:
https://youtu.be/A5Szbz-v6ng
2021-5-6
Buzzyone
Flight distance : 4647913 ft
As you photo shows the controller plugged into a laptop, I suggest you start by using the supplied power brick to charge the controller/motion controller.
The USB-C connector on a Mac may not be able to supply the current required to charge the controllers. I don't have the spec here but as a start use the brick provided.
2021-5-6
Depp
Flight distance : 1868796 ft
Buzzyone Posted at 5-6 09:58
My controller charges flawlessly even through a USB hub powered by a Mac - I never need to charge it because it charges while I fly in Velocidrone.
I don't know though if for the first charge you need to plug it into the power supply. With the Mavic Air 2 they had a problem with activating the batteries. Maybe this is something similar.
2021-5-6
bjr981s
Flight distance : 139698 ft
I plugged mine into my iMac Pro and had no issues. But I did use the USB port connected through my old Apple Cinema screen that is USB 2. I have had issues with the Mac USB 3 port for Assistant updates not recognising the drone / controller. Using a USB or Thunderbolt hub I have no issues.
2021-5-6
DJI Gamora
Hi, harrisrobin. Thanks for reaching out and our sincere apologies to read the difficulties you're experiencing. If you have tried different USB adapters for both the DJI Motion Controller and DJI FPV Remote Controller and the problem continues, it is suggested returning both to our Service Center for further inspection. You can reach out to our Customer Support: https://www.dji.com/support to assist you to open a ticket.
2021-5-7
harrisrobin
Hey Buzzyone, this worked!
Thank you.
@DJI Gamora, looks like the issue was that i had to use the power brick that's for charging the drones batteries, nothing else worked. I tried my laptop, a wall outlet (iphone charger), but it really took the power brick to get it working.
Thanks fro your help everyone, this can be closed!
2021-5-7
harrisrobin
DELETE this duplicate
2021-5-7
WingmanGroup
harrisrobin Posted at 5-7 06:04
Thank you.
I would add that if you’re just now having this issue and you’ve had your drone for a while, then the chances are you did a recent software update to your devices and the next time you need to charge the remote you need to use the cord and power brick that came with the unit the first time you charge it after the update.   I have had to do this with my DJI FPV drone and then I can go back to using my regular cord.
2021-6-27
frankymusik
Flight distance : 27841053 ft
Oh no...
2021-6-28
fans1ac82934
Seems not to like USB-C to USB-C.  Wants to draw from USB-A into the C connector.  So use the appropriate cable.  Also - I made sure to power and register all of the components with DJI.  Everything charging lovely now.
2022-8-31
quirm
Switzerland
Charging everything needs some logistics I also have a problem with a moody DJI Motion Controller. I tried to plug it into all kinds of chargers (MacBook, iPhone 30W, brick with much higher output, etc.). The only solution which worked for me was to use a hub, plug its USB-C into anything (MacBook or iPhone 30W works fine), and then plug USB-A into the hub and the other end USB-C into DJI Motion Controller. In this exact order, the other way around it also does not work.
2022-9-1
fansa99ccfdc
quirm Posted at 9-1 10:48
[view_image]
This worked for me too.  Using a USB-A to USB-C cable from any charger/hub worked for me.  Note that I was having this problem with both the DJI Motion controller and the DJI FPV Remote Controller 2 and this solution worked for both!
2022-9-1
fans0d74e01e
Flight distance : 12280 ft
fansa99ccfdc Posted at 9-1 13:30
Yes! I found that the USB-C to USB-C cable they supply doesn't work for the Motion Controller... must use a USB-A -> USB-C cable.
2022-9-2
Buzzyone
The FPV Remote 2 & the Motion Controller, neither support PD charging.
Using a USB-A to USB-C cable will solve this problem, you will also discover that the Assistant 2 App will not connect to the controllers if you use a USB-C to USB-C cable. So if you're using a Mac, you will need the USB-A adapter. With this you should have no issues.
2022-9-2
djiuser_6Ypl5W2ZPluB
Flight distance : 115873 ft
This is the only way I could find to charge the controller
2022-9-4
virtualjoey
Flight distance : 490102 ft
djiuser_6Ypl5W2ZPluB Posted at 9-4 01:11
do the LED lights continue to flash while charging?
With my controller the first large LED turns on once I plug in the charger, the second smaller LED flashes 6 times then they both shut off. I've left them plugged in for hours with no noticeable charge.
2022-9-6
fansac6addaf
Thanks for this thread, thought I had a bad motion controller. Turns out any USB port that support PD (power delivery) fast charging WILL NOT CHARGE the motion controller. I didn’t have any usb a to c adapter around on vacation, which would solve this problem. I was able to find an old usb c dock in my camera bag and one of the loop through usb c ports on the dock didn’t support PD. Plugged the charger into the dock and then the controller into the old usb c port and it charged right up.
This should definitely be explained or noted, THE MOTION CONTROLLER LACKS THE HARDWARE TO BE CHARGED BY ANY PD ENABLED USB C PORT. Which is the only kind of charger that I carry with me.
2022-9-7
fans5b128451
This is a bummer, hopefully can be addressed in a firmware update...using a USB-A to C cable did the trick for me.
2022-9-10
fans5d079cd6
I could not get it to work with any USB-C to USB-C cable (like the one included) but was able to get it to work once I tried my own USB-A to USB-C. Glad this worked!
2022-9-19
djiuser_8iG3IO64MdBs
Flight distance : 11804 ft
Hello, all. I know this thread is a bit old. But I just got the DJI avata and was having trouble getting the new update onto my controller 2 so I didn’t have to use the motion controller. After I tried charging a bit more to hopefully get it to connect since it wasn’t, I noticed the charge wouldn’t even happen. I saw OP’s suggestion about trying the charge hub instead of the computer or wall. So I tried using my usb to c-type adapter to plug into the USB port rather than the type-c port. This Allowed me to not only charge but to finally connect the controller to upgrade the firmware. You can get these cheap off of Amazon. So glad I had them for something else. Hope this helps someone else with the issue and I hope it helps DJI learn about the issue to raise concerns and hopefully get it fixed in future updates.
2022-9-28
fans10245dfc
fans1ac82934 Posted at 2022-8-31 07:50
I second what you said. It didn't like my usb-c to usb-c cord out of same power brick I used a usb-a to c and started charging. So weird
2023-3-10
Romeo Kienzler
Just make sure u use a QC compliant charger - PD doesn't work
Afaict C to C is always PD
A to C is QC or standard USB 5V, both should work, the latter super slow of course
4-3 13:23
dcobb23.me
Flight distance : 633386 ft
I was having issues charging my FPV controller, out of the blue. Tried all sorts of charging sources, but the USB-A to USB-C was the issue. Weird. Thanks!
4-22 16:32
fichek
Flight distance : 915233 ft
Croatia
Happy to report this has been fixed with new FPV RC3 and RC Motion 3, they both finally support PD charging, as well as proper USB-C to C data transfer (for fw updates, activation, and sim use on FPVRC3).
yesterday 00:14
