Pocket 2 wont connect to PC through do it all handle/USB.
5401 12 2021-5-7
Swarook
Connecting Pocket 2 to PC through USB directly works fine. Connect the "Do it all handle" then try to connect USB to PC,  I get a prompt on the device asking to accept the connection. I click accept. Nothing happens. Remove "do it all handle" and connection works fine again. Tried cords that come with device as well as multile random USB C cords I frequently use to transfer data.
Every cord does the same. Works straight to the device but "do it all" handle does nothing.
tested on multiple PCs and all the same result.
2021-5-7
TechDennis
I have the exact same! Tried different computers. Seems like the handle doesn't let data pass through only for charging, what is this DJI?
2021-5-7
HGDC84
Finland
I have been able to transfer data through USB-C even with the Do-It-All handle connected, so I do believe it is for both power and data transfer.
What kind of USB-C cable are you using? Did you buy the Creator Combo package that came with the Y-shaped USB-C cable with one basic USB and two USB-Cs? If you are using that Y-shaped cable, be sure to use the USB-C connector with the USB symbol embedded on it. One of them only transfers power for recharging, the marked one transfers both data and power. I certainly missed it the first time I tried it. To see more, check the thread here: https://forum.dji.com/forum.php?mod=viewthread&tid=238553
2021-5-7
Swarook
HGDC84 Posted at 5-7 12:04
I am using the correct side, and have tried multiple USB c cords with all having the same results.
2021-5-7
HGDC84
Finland
Swarook Posted at 5-7 12:09
OK, sorry to hear that didn't solve the problem.
A similar thread exists, considering  the same problem. I made a couple of other suggestions to try to solve it. You can see them at https://forum.dji.com/forum.php? ... D765%26typeid%3D765
2021-5-7
Swarook
TechDennis Posted at 5-7 10:51
I chatted with support they are looking into it and offered to just replace the handle. If i get a resolution ill add it here and if I end up just replacing ill let you know.
2021-5-7
Blériot53
Flight distance : 6188465 ft
I had this problem at first, but I found that there's a sequence of connecting that works:  First, connect the USB - C cable to the DIA handle, with the device switched off.  Then switch it on, and after it has done its boot-up sequence, only THEN plug the other end of the cable into your PC.   Works for me.  Hope you find the same result.
2021-5-20
Skaven252
Sweden
I'm having the same issue. When I plug the Pocket 2 (with DIA handle) to the PC when it's on (as suggested above), Windows makes a "device connected" notification sound. A "Connect to PC?" prompt appears on the Pocket 2 screen. When I tap Accept, the PC makes a disconnect sound, and the connection won't open - it never appears as a browsable device/drive. Also, the Pocket 2 becomes unresponsive until I unplug it.
No biggie since I can always use an SD card reader to transfer the footage, but kinda annoying still.
2021-10-22
Skaven252 Posted at 10-22 23:20
Hi there, sorry for any inconvenience caused. It's not recommended to use the USB-C port of the Do-It-All Handle to transfer data. We suggest you remove the Do-It-All Handle or use a card reader to copy photos and videos.
2021-10-23
HGDC84
Finland
DJI Mindy Posted at 10-23 01:40
Thank you for that info. Even though I have sometimes been able to transfer data through the DIA Handle's port, it has felt a bit iffy and acted erratically sometimes. I was even wondering if my USB-C cable is faulty. I'll have to try without the handle next time, then.
2021-10-23
HGDC84 Posted at 10-23 02:47
You're welcome. Hope it can help. Should you have any further inquiries, please feel free to contact us.
2021-10-23
flyfisher530
Blériot53 Posted at 2021-5-20 14:55
Had the same issue, and this worked for me 11-29-2023 for the Osmo Pocket 3!
2023-11-29
Blériot53
flyfisher530 Posted at 11-29 17:26
A shame that the issue hasn't been resolved by DJI in this new iteration of their product
2023-11-30
