hallmark007
Flight distance : 9812789 ft
Stu.Baby Posted at 5-13 14:52
The "bug" is in how the flying mode is conveyed to the user, not with the flying mode that the drone is in.
I had been flying in what I thought was Cine mode. I just accepted how it flew. I don't have a benchmark nor a rack of DJI drones to make comparisons with. I will be guided by what the manual, RC and app tell me which, at the moment, is absent or incorrect.
I keep hearing potential hazard , but this is the way dji drones have worked for the last few years,
Ok Ill ask you the question, is it important to check hardware before flying, if so then you won’t make any mistake, the app is showing what the hardware “Switch “ mode its in .
But the OP insisted that the change needed to come in the app, so lets see how that works.
The app says Normal mode but the switch says sport mode, why is this not a hazard, surely the problem is that the app and hardware need to match, but dji cannot be with you while flying to tell you to switch to normal mode, yet the OP didn’t even see this as a problem. And it was mainly because of this was why I pointed out that pilot must take some responsibility.
Reading between the lines here most think if the app auto changed then it would be ok no problem, until of course you look down at your RC and think your in sport mode but craft is flying in normal mode.
The OP’s biggest concern was he couldn’t rapidly take off in sport mode, but he should know by now thats impossible on all dji drones Maybe exception FPV.
You say you’ll be guided by what the app and remote tell you, so if app says normal and remote says sport, which one do you use ? And this is the crux it seems your happy that the op pointed out the problem with the app, but because I point out the problem with the RC + App people are defending the OP, for what I have no idea, because I simply pointed out that the op should know and he only knew half the problem…
As I said earlier Common Sense around here is not very common… |
