Is 80% -> 100% charge SLOWER than 0% -> 80% ? Stop at 80% if hurry?
312 4 2021-5-10
Mike90210
Flight distance : 1183556 ft
I foolishly didn't charge batteries last night because there was a temporary FAA flight restriction.
Apparently, it got cancelled or I misread it.
So, I'm anxious to fly.
QUESTION: Should I take first battery off the charger at 3 dots instead of 4 so the next battery can charge?
Thoughts?
Thanks,
Mike
2021-5-10
GaryDoug
Flight distance : 1264639 ft
I can't answer with any certainty but I would think the charge rate is independent of the level. So I would leave the first battery on the charger until it is fully charged. Most battery chargers regulate the amount of constant current applied to the battery, not the voltage.
2021-5-10
DJI Stephen
Hello there Mike. Good day and thank you for reaching out. It would be best to fully charge the first intelligent flight battery before charging the next intelligent flight battery using the provided DJI charger to prevent any unwanted issues in the future and for you to be able to maximize the use of your DJI Air 2S intelligent flight battery as well. Thank you.
2021-5-10
DAFlys
All lithium batteries charge slower for the last 20%,  you can see this effect in mobile phones too.
2021-5-11
FB: GeoDrone4K
Flight distance : 2676129 ft
Romania
Or just buy a multiple battery charger for Air 2...works very well with A2S...DJI should make this but they had a lack of vision speculated by other producers...Why DJI?
2021-5-13
