1/ 2,3" sensor dimensions
264 4 2021-5-11
djiuser_DJX4tMAeghTH
Flight distance : 5466 ft
Hello I would like to know the true dimensions of 1/2,3 inches sensor on Mavic Pro. I mean, wide, height, diagonal?
Can you tell me, please?
Thanks!
2021-5-11
ArcticPhoto
Norway
Diagonal: 7,66mm
Width: 6,17mm
Height: 4,56mm
Area: 28,07 square mm
Found here: http://photoseek.com/2013/compar ... thirds-1-inch-type/
2021-5-11
Thank you!
2021-5-11
DJI Stephen
Hello there. Good day and thank you for the inquiry. In addition to the post above I will post the camera specifications of the DJI Mavic Pro below. Thank you.
2021-5-11
Thanks, Dji Stephen and ArcticPhoto.
On top of the above dimensions, I need one more thing. The true focal distance of DJI´s 1/2,3" sensor.  Above is said 26 mm (35 format equivalent) but I mean, note the equivalent, but the true focal. Or how can I calcuate it?
Thank you
2021-5-12
