Beta firmware for RS2 (hotfix for BlackMagic)
5513 29 2021-5-13
DJI-Paul
Flight distance : 41159547 ft
South Africa
Thank you for your interest in this beta firmware. By downloading or using this beta firmware, you hereby signify that you have read carefully and that you understand and agree to abide by the terms and conditions herein:
1. Beta firmware is not yet fully tested and is mainly used to gather feedback prior to regular release. This enables users to be involved with the development process and for any necessary changes to be made prior to the regular release schedule.
2. The beta firmware and all related services are provided "AS IS" and, to the maximum extent allowable under law, DJI disclaims all warranties of any kind, whether express or implied, including any warranties of merchantability, fitness for a particular purpose, and non-infringement. Without limiting the foregoing, DJI does not warrant that operation of the beta firmware will be uninterrupted or error-free, that the beta firmware will be compatible with any products including designated DJI product models.
3. DJI will not be liable to you for any personal injury, property damage, lost profits, cost of substitute goods, loss of data or any other form of direct or indirect, special, incidental, consequential or punitive damages from any causes of action arising out of or related to this agreement or the beta firmware, whether arising in tort (including negligence), contract, strict liability or otherwise, whether or not DJI has been advised of the possibility of those damages.
4. If you find any abnormality when using the beta firmware, we recommend that you take the following steps:
a. Send feedback on the problems you encounter. You may contact us through our firmware release channel (whether DJI’s Official Forum, or the Official DJI RS2/RSC2 Owners Facebook Group);
b. It’s possible to downgrade to a previous version of the official firmware. Set the gimbal to sleep mode, go back to the homepage of the App, and click the upgrade notice. The original gimbal firmware should then be restored.
RS2 Beta
RS 2 firmware version: 00.00.00.02
What’s New?
Fixed BMPCC camera control.
2021-5-13
DJI-Paul
South Africa
2021-5-13
Indio
Flight distance : 303373 ft
Austria
many THANX !!!
2021-5-13
Mr Sin
Flight distance : 92231 ft
Thank you!
2021-5-14
Rob W
Flight distance : 94390 ft
Sweden
Thank you, DJI! I will install it tomorrow.
Hope DJI is also working also on a new Inspire 2 firmware, because the latest one is dangerous as you can loose control of the aircraft without being able to return control, and it is supposed to fix a dangerous issue with the previous firmware. So we only have the choice between two dangerous firmwares...
2021-5-14
Rob W
Sweden
Seems to work! I've only tested a little while, though.
2021-5-14
Guido-Italy
Flight distance : 477008 ft
Tks DJI-Paul
2021-5-16
Guido-Italy
Hi DJI-Paul I downloaded beta but pressing rec button BMPCC doesn't start rec. Any information ? Thanks
2021-5-16
Guido-Italy
Guido-Italy Posted at 5-16 04:07
Whith .02 version it' work !!!
2021-5-16
johndus
Guido-Italy Posted at 5-16 05:04
But now focus motor is broke
2021-5-17
johndus
2021-5-17
Indio
Austria
johndus Posted at 5-17 08:24
no, is working for me with the focus dial
next i will test 3D focus
2021-5-17
Guido-Italy
no words !!!!
2021-5-18
DJI-Paul
South Africa
johndus Posted at 5-17 08:25
The beta firmware didn't change anything else besides camera control. If you go back to your previous firmware is your focus motor working?
2021-5-18
djimac
Belgium
Everything started working back for me with the .02 update, the record button and the focus button too.
2021-5-22
djimac
Belgium
2021-5-22
fans80db2774
Can't seem to download the hot fix. When will this fix be coming to a regular RSC2 Pro firmware update? Or is there any way to downgrade from 7.3 firmware on the BMPCC4k?
2021-5-26
fu64L
Everything works well! Both record button and focus wheel – fine!
Thank you!
2021-5-26
betopicharillo
Brazil
Hello friends. How do I download
2021-5-27
Guido-Italy
Hi do you have any news about final fixed version ?
2021-5-27
Indio
Austria
betopicharillo Posted at 5-27 10:12
read the thread
2021-5-27
Indio
Austria
fans80db2774 Posted at 5-26 11:13
see the first post - it is in the app
for the BMPCC:
remove 7.3 setup -  download 6.9.6 >install and connect your camera
2021-5-27
Mark Roush New Adjustment
Hello. On my DJI app, when I click on Firmware it doesn't allow me to click on any of the options i.e. App Version, Firmware, RavenEye, IMU, GCU....
From that, I can't downgrade to try and get my record button to work.
I have a DJI RS-2 w/ BMPCC6k.
Advice?
2021-6-12
Gravel guy
Downgraded .02 and now the record button works on the main handgrip , but not on the remote cabled hand grip. . Can't DJI just fix this issue and be done with it?
2021-6-13
Indio
Austria
Gravel guy Posted at 6-13 18:17
do you have also the latest firmware on your hand grip and camera?
or remount the adapter on the ronin
my set works as it should
2021-6-14
Indio
Austria
beta 004 is available
better support for some steadycam units (tilta float,  . . . )
2021-6-16
FVP
I tried Beta 004 on my Steadycam.
- we still cannot deactivate the PAN and / or TILT motor
There is a Steadycam function:: panning is better but it is REALLY not enough for fast movements.
The tilt is unchanged and too smooth.
We need a fully locked down system for to be used on a Steadycam.
2021-6-17
shkarinov
Russia
I have tried all firmware (01,02,04).
No one works with my bmpcc 6k with firmware 7.3.1
On 02 firmware rec button is working and if i change wheel to iso or aperture it works also. But focus is not working.
Returned back to 6.9.6 on bmpcc.
Wait for firmware that will fix focus wheel.
2021-6-19
Indio
Austria
shkarinov Posted at 6-19 00:54
first there is no 7.3.1 firmware for the 6k > only for the 6k pro
for me, beta 002 give me focus wheel control for all of my sigma art, canon EF and tokina pro II lenses
on my 4k with metabones cine and also my 6k pro
2021-6-19
macmediaavg
Downgraded to .02 firmware and all aspects seems to be functioning correctly with the bmpcc 6k pro 7.3.1 update. Cheers
2021-7-5
