fc_log.log
3213 6 2021-5-13
djiuser_nO2RdSW5BSUg
Flight distance : 80646017 ft
Poland
Is it now possible to view the fc_log file saved on the sd card? Unfortunately, it has a volume of 512MB. Airdata rejects such a large file.
2021-5-13
relaxosmo
Flight distance : 180604 ft
Hungary
Upload the flight log from the log folder of dji fly app on your phone. I also dont know why my LOG folder on SD card is 1 GB!!
2021-5-13
Poland
I need a fly record from an sd card, not the one from a smartphone. I want to know what happened after the connection was lost. File extensions are different. There is a .log on sd and a .txt on the smartphone. The sizes are also very different. I mean, how and is it possible to view this fly record from the card?
2021-5-13
jonny007
Are you sure that there is more information in the fc_log.log and why not in the DJIFlightRecord * .txt or in the * _fly * .dat in the directory MCDatFlightRecord ? These files usually contain everything you need, including disconnections. Airdata also only reads the log files.
By the way, the dji.go.v5\FlightRecord\MCDatFlightRecord and also the complete log directory dji.go.v5\Log can be deleted. The logs in dji.go.v5\FlightRecord I move to the pc from time to time.
2021-5-14
Poland
Imagine a situation that you lose range, e.g. due to a discharged battery in the RC. The drone returns in the RTH procedure and does not reach the homepoint, but lands earlier, much earlier. Would you like to know why. You don't have it on DJI fly. This is included in the fc.log file on the sd card. And I'd like to know that. The file is large, because it is not a log, but the whole history of recorded flights, similar to fly export from Assistant 2. Can I view these records and where?
2021-5-14
jonny007
Yeah, I get what you want, but how do you know what's in this log if you've never seen its contents? I doubt whether historical data are stored there, because the file does not grow, it has always the same size, whether you have made 0 flights or 100. Or it is a kind of swap file with an always fixed size. In any case, they cannot be read out with the usual analyzers. Probably only from DJI.
2021-5-14
Poland
FC means: flight control, so it contains flight data. It's a shame there's encrypted content there and there's no way to see it.
2021-5-14
