Downloading images from mission
2921 2 2021-5-14
ds9193
Flight distance : 64469 ft
Hi, I did a survey mission with my new m300 yesterday using the ZenMuse P1 which seemed to run fine. I assumed that the images would be stored on the micro SD card on the camera, but all I could see on there after the flight was a log file. My question is, where are images stored on the M300? Is it the controller, the drone itself, or have I made a mistake with the SD card on the camera? Thanks in advance! I'm used to phantoms, which are much simpler!
2021-5-14
fans5b25584c
Flight distance : 24012 ft
Under the rubber strip on the side of the P1 is a full sized SD card.
Kind of hard to see, but when you push in on it, it releases and comes out.
Everything is stored on there in the DCIM folder, meticulously separated with a folder for every flight.
2021-5-15
ds9193
fans5b25584c Posted at 5-15 12:57
Thanks! Found it,was starting to think I'd lost it
2021-5-15
